CLICK HERE--><--CLICK HERE
Fox .25 NVA / Venturi
Started by Tres Lawton, July 08, 2026, 04:04:44 AM
Previous topic - Next topic
0 Members and 1 Guest are viewing this topic.
Tres Lawton
Hello All,
I have two .25 Fox engines (plain bearing wt. flange mounted venturi) that have different NVA / spray bars, and I am trying to determine which NVA is correct or best.  I believe them to be late model engines due to the muffler mounting lugs on the exhaust stack sides.  One engine has a .157" spray bar with a compression spring to hold the sharp needle and the other has .125" spray bar, blunt needle wt. flat spot, and U-shaped bracket to hold needle like a typical Fox .35 NVA.
Any help determining the correct and or best NVA / Venturi set up would be greatly appreciated.
Tres
M Spencer
The foist one roit .
Theres STEEL prop driver 19's & 25s . Mostly theyre retimed a bit from the alloy flog out prop driver voisin .
https://sceptreflight.com/Model%20Engine%20Tests/Fox%2025%20CL%20%282%29.html
9 x 4 stunt or 8 x 6 for riots . or 7 x 8 for Rats .
Tres Lawton
Quote from: M Spencer on July 10, 2026, 05:37:20 PMThe foist one roit .
Many Thanks M for the help!
Based on the effective area stated in Peter Chin's Fox .25 engine review, it appears that my .157" Dia. spray bar would be the stock / correct NVA.  As the .125" spray bar would yield an approximately 50% larger effective area than stated in Chin' review and the .127" spray bar is pretty darn close.  The engine is going in a very nice old Blue Bird ship, so I want to make a best effort at not having a FOX ROCK on her maiden flight due to the wrong NVA.
Tres
M Spencer
Hurumph .
The 25 will run a bit steadier than the 19 , a 9 x 5 no sweat .
Like being damp , starting . used the 27 % oil , as liners unhardened . ( If the weathers hot )
They dont object to NITRO .  Heres a thing , https://outerzone.co.uk/plan_details.asp?ID=10342
might be some help as to ' wot'll she do ' .
