Randy,
Maybe you can shed a little light on this.. Several of us in the club are going to play Carrier next season and are using TT 36's. We have accumulated 6 engines and seem to have two versions. An earlier version and the latest version. We have found the latest version has about a 2-300 RPM edge over the earlier version Running the same fuel, carb and prop.
Just wondering what the difference might be and if you know if they changed the timing or? Also don't you replace the P&L when you build an Aerotiger? How many stock P&L's do you have laying around
Hi Bob
The TT 36 has went thru many changes, the shaft timing and sleeve timing has been changed a very slight amount, the head, case, and bearings size and type has been changed also. Why the new ones may turn 300 more RPMs could very well be the newest ones have phenolic beaings instead of the stamped steel caged ones.
Also the new ones have a shorter crankshaft and a larger front bearing
I have all parts for the engines
