  • June 16, 2025, 10:57:39 AM
Author Topic: Fox .201  (Read 2633 times)
Offline Bootlegger
Fox .201
« on: January 01, 2021, 08:09:09 PM »
 Guy's I need some advice/suggestions as what size (s)  prop to use on this engine in a stunt model.  Obliged,
8th Air Force Veteran
Gil Causey
AMA# 6964
Re: Fox .201
« Reply #1 on: January 01, 2021, 08:11:29 PM »
  Same as on a 19, maybe an 8-5 or 8-6?
Online Dennis Toth
Re: Fox .201
« Reply #2 on: January 02, 2021, 07:00:22 AM »
Boot,
Are you running a muffler or open face? Open face you could use a narrow 9x5 or 6 (like a Zigger or MAS) with a muffler you need to drop to the 8 ish diameter maybe cut down a Brodak BY&O 9x5 or 6 to keep the engine running cool. What ship are you planning to use it in? Again if open profile lots of cooling can push the diameter up a bit, if cowled need to go toward the smaller diameter to reduce load and heat. Also, use fuel with at least 25% total oil of which it should be at least 50% castor.
Best,   DennisT
Online Robert Zambelli
Re: Fox .201
« Reply #3 on: January 02, 2021, 07:19:14 AM »
Go with what Brett said.
However, I've also had good results with the old Top-Flite 9-6 wood props.
I have a few of the .201s and there is virtually no difference between it and the Fox .19.
Having run quite a few of these from the 50s, like the .19, .201, .25, .29 and .35, I caution the use of mufflers.
I have tried a number of different mufflers and most if not all have caused overheating.
I have hundreds of flights on the above mentioned sizes and I've used only Brodak 10/23, 50-50 oil and all the engines run perfectly.
The engines were acquired both new and used.
Bill Mohrbacher (SP?) told me that the reason for the .201 was to be able to use the same plane in two different classes - A, up to .200 and B, .201 to .30.
Bob Z
Online Dan Berry
Re: Fox .201
« Reply #4 on: January 02, 2021, 04:48:45 PM »
Use whatever you would use on a Fox 19.
There is a ...... rumor ........ in the Free Flight community that the Fox .201 is actually a Fox 19 with a different mark on the case.
Offline Dane Martin
  • heli pilot BHOR
Re: Fox .201
« Reply #5 on: January 02, 2021, 08:11:20 PM »
Huh? You mean my highly sought after torp "201" is nothing but a low rent 19 cleverly disguised?? Dang.
Online Dan Berry
Re: Fox .201
« Reply #6 on: January 02, 2021, 08:31:47 PM »
No rumor. You can see where the .19 was filed off and the .201 stamped in. This was done for the free flight folks. Put it in class "B" . D>K
I understand using the same case.
I've been told that internally they are identical.
Online Dennis Toth
Re: Fox .201
« Reply #7 on: January 03, 2021, 01:09:55 PM »
Here is a source for information on the Fox 19  http://sceptreflight.com/Model%20Engine%20Tests/Index.html
If you look in the Glow/Ignition tab you can see a couple reviews for the Fox 19 (1954 model). It looks like it could run the popular 9x4 setup at 13K with will keep up with the OS 20FP setup. No listing for the Fox 20.
Best,   DennisT
Re: Fox .201
« Reply #8 on: January 03, 2021, 01:26:59 PM »
  Not a chance, not even in the same league. It can probably make it up to level flight speed with that prop, but it will be dead-dead-dead in the maneuvers. I tried a bunch of engines like this, no way, including the roughly equivalent OS-20S and stronger 25S.   The Veco 19BB can barely manage,  this is much weaker.
   If you want that kind of performance, you *have to get a decent modern engine*, there is nothing you can do with these old baffle-piston engines that will make them match up.
Offline Dan Bregar
  • Field Marshall
Re: Fox .201
« Reply #9 on: January 28, 2021, 03:16:59 PM »
I still have a couple of 19's & 25's as well as a 201. These are roughly 64/65 vintage and the 19's would do 85mph on a Jr. Flite Streak with a yellow Grish 8x6. They liked that prop. I flew the 25's on a Firecat with the Revup 9x5 and it was pretty capable on 52 ' lines. These 19's had a lot more steam than the 15's which I thought were pretty poor power wise. The 19's were close to the Veco 19 power wise and I always thought they were pretty good.  :)
Dan
AMA 33676
