  • June 21, 2025, 03:41:04 PM
Author Topic: to fill or not to fill  (Read 762 times)
Offline roger
« on: March 09, 2008, 07:40:06 AM »
this is my 1st twin engine job the question is what engine do i want to quit first, the in board or out board. and why? and any other input would be helpful too.
roger D>K
Alan Hahn
Re: to fill or not to fill
« Reply #1 on: March 09, 2008, 10:32:44 AM »
Well I would guess you want the outboard to quit first since if the inboard is running by itself, it will yaw the plane outward. The opposite (outboard running, inboard off) would yaw the plane inward---not a comfortable position to be in!
Offline Mike Spiess
  • bikemike
  • AMA #4060
« Reply #2 on: March 10, 2008, 01:02:07 PM »
With my experience with twins is that if the plane is set up to fly stunt well then as long as you fly level it doesn't matter. Just don't try any maneuvers LL~ HB~> They will have less line tension with outboard motor but it never seemed that bad.
You don't stop flying cause your get OLD
You get OLD cause you stopped flying
St Peter MN
Present Master of the Figure 9
