  • June 14, 2025, 11:49:58 PM
Author Topic: Replacement needle valve assemblies  (Read 1812 times)
Offline kevin king
« on: January 23, 2023, 10:49:16 PM »
Nice. The replacement fox nva are good to know too!
Re: Replacement needle valve assemblies
« Reply #1 on: January 24, 2023, 07:46:20 AM »
These will work but they require the venturi area a bit so you get better fuel draw be less power then the ones that Randy S sells that have the same end diameter but a reduced center to match the original FOX NVA diameter.
Best,   DennisT
« Reply #2 on: January 25, 2023, 12:03:27 PM »
Looks like they include some sort of plastic washers for each end. Maybe that works, but I tried that (not with RSM plastic washers), and the entire spraybar turned when I was adjusting the NV. Not what you want, OBTW.  n1 Steve
Offline Chris Lambdin
« Reply #3 on: February 02, 2023, 04:08:51 PM »
Does Randy Smith still sell his PA NVA for the fox?
Offline Joe Ed Pederson
« Reply #4 on: February 03, 2023, 01:04:35 PM »
No, he doesn't.   I called and asked him before Christmas.
Joe Ed Pederson
Offline Peter in Fairfax, VA
« Reply #5 on: February 04, 2023, 06:02:40 PM »
My original Super Tigre NVA Fox 35 ran great.  If drilling the case to get it in was needed, and it restricted the venturi a bit, I didn't mind.  Fuel draw, economy were great.  I miss that engine.  Also had a good fitting chip muffler.  Probably a 50th or 60th Anniv.  Thought I'd never fly Fox 35 again.  Now I am rigging advanced trainers setup for Fox.
Back to the NVA, I'd say an original Super Tigre or an RSM would be fine, even an Enya if that's your style.
Peter
