  • June 20, 2025, 07:49:37 AM
Author Topic: Stalker muffler twist  (Read 1016 times)
Offline Michael Palm
« on: December 26, 2014, 08:11:56 AM »
I think I read somewhere that its possible to heat the muffler so you can twist it so the outlet gets where you want it. I have tried whith a propane tourch but i am afraid to heat it to much. Is there a trick to know how much heat you can put on?
« Last Edit: December 26, 2014, 10:26:40 AM by Michael Palm »
R/C is disco, C/L is Rock n Roll
Offline tom brightbill
Re: Stalker muffler twist
« Reply #1 on: December 26, 2014, 10:09:27 AM »
I've been successful by using a Monokote heat gun and a lot of patience.  It takes a long time (15 minutes?) to gradually get the end cap up to temp so that it will move. Putting a drill bit of the matching size into the outlet will allow you to put pressure in the joint and feel when it is getting ready to come loose. I removed the cap and cleaned off the mating surfaces so that none of the cooked adhesive remained, then re-glued it with JB Weld.
AMA 34849
« Reply #2 on: December 26, 2014, 01:35:14 PM »
Thanks for the answer Tom. I will try with my heat gun then.
Happy New Year!
