  • June 20, 2025, 12:27:10 PM
Author Topic: ST V60 with PDP  (Read 1126 times)
Offline Martin Quartim
    • StuntHobby
ST V60 with PDP
« on: December 20, 2006, 05:16:57 AM »
Did all the ST V60 with muffler lugs had PDP porting, or there were a few without it?
thanks,
Martin
Online RandySmith
Re: ST V60 with PDP
« Reply #1 on: December 20, 2006, 03:14:33 PM »
thanks,
Martin
Hi Martin
No all of them did not have PDP porting, and you will NOT find much of  any differance in the 2 engines  unless  you run the ST 60 in a  very fast 2 cycle, the PDP porting only gave a boost  when you run the motor in a  flat out 2 stroke hi RPMs.
  Also the ST 60 will  beat itself to death  running  hard , especially the rod.
