  • July 04, 2025, 02:38:50 PM
Author Topic: Fox "burp" plug?  (Read 1548 times)
Fox "burp" plug?
« on: January 30, 2015, 03:10:30 PM »
OK, guys, don't tell me to "search", i did that.  ;D  What i want is the actual dimensions for the wooden plug for the bypass?  Need the thickness the worst.
Thanks!
BIG Bear
RNMM/AMM
Re: Fox "burp" plug?
« Reply #1 on: January 30, 2015, 05:42:24 PM »
Make it about 3/8 wide and keep whittling on it to fit between the case and the sleeve. I use bass wood and form it to fit the curvature of the sleeve. Chamfer the end where it sits on the case ridge to keep the rod from hitting it. I think a Popsicle stick will work.
« Reply #2 on: January 30, 2015, 06:06:52 PM »
Thanks a lot Bro Jim.  I can go from there.  ;D
Bro Bill
Offline Dennis Vander Kuur
« Reply #3 on: February 11, 2015, 01:35:56 PM »
Bill,
See picture below.
DennisV
Dennis L. Vander Kuur
AMA 29292
Offline Terry Caron
« Reply #4 on: February 11, 2015, 03:47:35 PM »
Bill -
I used the same diagram Dennis posted, 2 popsicle sticks were just right thickness and width, but I had to trim the length some.
Worked fine.
Terry
NACA member, Huntsville, AL
AMA 249824
NRA Life Member
