Engine basics => Engine set up tips => Topic started by: Bill Little on January 30, 2015, 03:10:30 PM
OK, guys, don't tell me to "search", i did that. ;D What i want is the actual dimensions for the wooden plug for the bypass? Need the thickness the worst.
Thanks!
BIG Bear
RNMM/AMM
Make it about 3/8 wide and keep whittling on it to fit between the case and the sleeve. I use bass wood and form it to fit the curvature of the sleeve. Chamfer the end where it sits on the case ridge to keep the rod from hitting it. I think a Popsicle stick will work.
Thanks a lot Bro Jim. I can go from there. ;D
Bro Bill
Bill,
See picture below.
DennisV
Bill -
I used the same diagram Dennis posted, 2 popsicle sticks were just right thickness and width, but I had to trim the length some.
Worked fine.
Terry
