  • July 12, 2025, 08:25:37 PM
Author Topic: Follow on question o the OS 20 FP running with hole in crank case  (Read 6899 times)
Offline Fredvon4
  • Central Texas
I have a few new ringmasters and a soon to be built SkyRay as well as another sone to build  arger Ringmaster from Pat Johnston...the 526 RM will get one of my new in box Evo .36
I have been impressed buy the Bret Buck recommendation of the OS 20 and associated BBTU commentary and my personal experience is this system works a tad bit better than the Old skool Fox 35...but truth is I used a LA 25 and it is not the real FP 20 BBTU..so I went in search of hardware for future models
That all said, I am a casual flyer...no contest aspirations. I just want to find myself at the field with a power system that does not demand a lot of fussing around
The Fox 35 (no burp plug) on one (Mike Griffin ARF RM) is prefect for my psuedo stunt flying
I built a RST with RM tail and it is powered by a blue La 25 and near perfect for me also
I have traded for one FP20 but it is the large hump so called "iron liner" version and runs fine on the bench
I recently won a FP 20 no hump, assumed ABN version, and it too starts and runs fine on the bench
I am using the OS Venturi and NVA assy as well as the 2030 muffler fed with home brew 15% N...22%oil half half and each starts and needles with a fairly broad NVA range from 8000+/-Rpm up to 11,800~12,200rpm using a  typical 9x4 prop
OK now the question....
I thought the ABN version was the preferable one----- until I read recently that the Iron liner one was stronger....in this thread
http://stunthanger.com/smf/open-forum/ringmaster-with-a-os-25/?topicseen
where Phil Spillman claimed the Iron version was preferred.......so I am confused
Am I concentrating on finding the wrong OS FP engines?
Or is the FP 25 that much different from the ABN BBTU FP 20 so I am just mixing apples and avocados?
Thoughts....opinions?
Just for reference I have
1 OS LA 25
1 OS FP 25 Iron
1 OS FX 25 ABN BB
1 Magnum 25...ABN BB
1 ASP 21 ABN BB
1 OS FP 20 Iron...plain bearing
1 OS FP 20 ABN...plain bearin
And several tongue and OS /ASP mufflers assys as well as the OS 20/25 Ventrui and NVAs
Fred von Gortler IV
Online Tim Wescott
Re: Follow on question o the OS 20 FP running with hole in crank case
« Reply #1 on: July 29, 2016, 02:15:16 PM »
AFAIK, the "BBTU" really refers to the ABN version of the 20FP.  I don't know Phil, so I can't say whether he's on to something or not.
Also AFAIK, the 25FP does not have the magic that the 20FP does.  But, lots of folks have enjoyed flying with them, so they can't be a total loss.
Keep in mind that there are a lot of different opinions floating around about what makes a good stunt engine, and what makes a stunt engine good.  Many of them are contradictory.  Follow the wrong guy's recommendations and you won't be happy.  Moreover, if you try mixing and matching recommendations from two dissimilar engine philosophies, you'll almost certainly end up with something that combines the worst characteristics of both.
To my knowledge, any of the engines you mention should work, however the ball-bearing ones are all designed to be higher performance engines, and as such will be happier turning flatter-pitch, possibly smaller, props faster than the FPs and LAs.
Ultimately, you've just got to experiment and see what works for you.
Offline Fredvon4
  • Central Texas
« Reply #2 on: July 30, 2016, 06:54:09 AM »
Thanks Tim
I went back and reviewed a bunch of the FP 20 BBTU threads. I see that I missed the discussion about the 2030 Muffler and ABN OS FP 20 seeming to have a tuned pipe like effect in the Stunt RPM range with the 9x4 prop
It was suggested that this was not true for the OS FP 25
Also various other discussion on SH and SSW about the FP 25 do not really get into either version being better or different until the Phil Spillman comment that was specifically about the FP 25
I plan to use the heavier and faster FX 25 Ball bearing versions on several combat wings instead of a hot rod .36 combat engine
so I guess I was reacting to Apple/ vs Avocados thinking
Fred von Gortler IV
Offline Andrew Tinsley
« Reply #3 on: July 30, 2016, 09:53:50 AM »
The ABN version is "the" Brett Buck desired FP20 with the E2030 it does give a tuned pipe run, but obviously on a harmonic. Brett says that the Iron FP20 doesn't cut the mustard. Oddly I have iron ones that work every bit as good as the ABN version and some iron ones that don't. I suspect that one has to run them in very well indeed and then they will work in the BBTU set up. The OS25 doesn't seem to work with BBTU, but then it has more power and just run it conventionally.
Andrew.
BMFA Number 64862
« Reply #4 on: July 30, 2016, 02:07:16 PM »
       I don't think I said that the iron-liner engine wasn't any good. I haven't extensively run the iron-liner engine or the "842" muffler.  Others have reported acceptable results for the iron-liner engine with the e2030 muffler as long as you were careful about the fuel and break-in.
   And just to be clear, almost all the engines in the "small engine experiments" worked just fine bone-stock to varying degrees. All provided at least equal performance to the Fox/McCoy 35 on the small "35-sized" profiles we were using them for and much better handling characteristics. An important finding of the experiment was that almost any engine you could get at the time worked better than vintage engines for this application, as long as you left them alone internally, and used the correct propellor (i.e 4" of pitch like every other stunt plane does).
« Last Edit: July 30, 2016, 10:51:55 PM by Brett Buck »
Offline Fredvon4
  • Central Texas
« Reply #5 on: July 30, 2016, 02:50:05 PM »
Thanks Bret...that was mostly my take away from your extensive musing on the subject as well as the posting of Dan Rutherford
When I returned to modeling I was a tad dismayed to find the engines I remembers from my youth almost always had some hacking/magic applied.  I was frustrated to NOT be able to get definitive "recipes" for these mods/ hacks...Tom Dixon, Marvin Denny, GMA who ever...
When I found the (long ago) mention to the BBTU I was intrigued and found myself thinking, this is what I need....simple out of the box working power that is reliable and repeatable and to some degree tune-able
then I found all the detractors....some with arguable results......OK no sweat get some kit and get your own conclusions
I am now fond of my engine acquisitions from Fox, OS, ASP, and Evo
I doubt, pre internet, I could have subscribed to enough magazines to learn this much in this short a period
Thanks to all for the education, opinions, and guidence
Fred von Gortler IV
« Reply #6 on: July 30, 2016, 05:44:21 PM »
    You are quite welcome! The internet, for all its faults, is an absolutely amazing resource for stunt fliers. When I was trying to learn 40 years ago, there was very little and you had to glean the meager information by reading every single magazine article you could find, and learn to read between the lines. Now you can have direct access to mutliple national champions and many very knowledgeable master modelers in seconds.
    Back in the day, it was also common for experts to keep secrets, and you could actually do it. Now, absolutely anything anyone knows is immediately available and written down for you. No one can keep a secret any more, there are too many of us who will tell you anything we do, and, tell you what we think other people are doing.
 There are a lot of arguments, and back-and-forth with differing opinions, but arguments in general are really helpful. What is not helpful is the people who are intentionally attempting to tweak people and in the process, promulgate gibberish or known wrong information. For the first time ever, I got real-life angry at someone in Muncie for this sort of thing this year. But that is one incident in ~25 years of internet activity since the old compuserve forum days.
     BTW, I can describe the sort of modifications that most modifiers are doing -the same silly plan from 1980 when no one really knew what to do with the amazing power increase possible with schneurle engines. It's some combination of dropping the liner in the case (to reduce the exhaust duration), raising the intake port(s) by grinding the top edge of the ports (to reduce the blowdown), blocking the boost port (to reduce the high-RPM breathing), and stacking large numbers of head gaskets to decrease the compression ratio (to either reduce the 2-stroke power and/or overall power). The goal is to make it so you can run the engine at low RPM with a 6" pitch prop, and maybe in a 4-2 break. That's unfortunate because it once you make it run like a Fox 35, it has the same power as a Fox 35. This works sometimes, but in any case you toss away a huge fraction of what made the engine worth using in the first place, i.e. more effective performance.
   A few people almost figured it out in the early 70's. The West Coast equivalent of the AMA was called WAM, Western Associated Modelers. It was formed in the late 40's, and was about equal in stature. One interesting thing about WAM was that they had skill classes in every event (carrier, combat, stunt, speed, everything) right from the beginning, and this was the model for the PAMPA classes when those started in 1974.
    Anyway, another interesting thing about WAM was that they had engine size categories for every event including stunt. David Fitzgerald holds the WAM High Score Record for 1/2A, I hold the WAM High score record for both A* and BC, etc. At any rate, when Bay Area airline pilots Ted Fancher, Bill Fitzgerald, and Gary McClellan and their clan decided to fly stunt, they wanted to fly all the WAM engine classes. So they needed 1/2A airplanes (Cox 049) and A stunt airplanes. They experimented seriously, and came up with a more-or-less stock SIG Banshee using, wait for it, a Veco 19BB with a 10-4 prop running in a constant 2-stroke. This was in the mid-70's. The airplane flew so well that they may have been easier to fly than their "serious" airplanes at the time. But it never quite dawned on them to apply the same principle to the larger engines. Even when the OS 40FSR and other similar "schneurle of the month" engines came along, they still persisted in trying to run them like Foxes.
   Still later, when doing the initial experiments with 4-strokes in the mid-80's (before the Johnny-come-latelys declared them a "revolution" in the mid-90s - about the time they sold their last St60 that had been rusting on the shelf for 10 years), once again, the best performer was Ted Fancher's Enya 46 with - wait for it - a 12-4 spinning at about 11000 RPM. This of course was quickly dropped when the drastic performance improvement and amazing adjustability of tuned pipe engines came along - also swinging, wait for it, 4" of pitch.
     Ted and I, and then later, David, switched to piped engines about that time (1988-89) as did many others, and of course since then, this has been the de-facto system. Only recently has electric been a viable alternative.
   Anyway, I spent a lot of time helping, or at least trying to help, beginners and others try to advance. Almost invariably, they were trying to use either vintage semi-slag engines like the Fox on profile mounts, or OS40FPs of some sort. The stock Fox needs no further description, burping/crash/die on every outside corner, and at the time, the bypass stuffer had not been discovered. Even if it keeps running, it shakes the airplane to bits in short order. The unmodified 40FP was notorious for "runways", AKA, running as designed, which led to grossly excessive power/speed when used with 6" of pitch, and even too much with 4" of pitch. The modified 40FPs were just as weak as Foxes, although they would keep running through maneuvers. Piped 40FP's worked fine, but that was far beyond the desires/means/interest of most of the guys we are talking about.
   Anyway, during one of these sessions, out in the 100+ degree sun at Gilroy High School in Gilroy, California (home of the Garlic Festival), it finally dawned on my that the 40FP ran very well, but had about 2x the power it needed for the airplanes we were talking about. Say, if it has twice the power, maybe I need the same thing about half the size. Then it dawned on me what they had done with the Veco 19BB back in the 70's was analogous and how 4" of pitch was responsible for most of the performance increase from piped engine and for the 4-strokes. But it still didn't quite click.
   Shortly thereafter, David and I were up flying at the old Napa site, and a guy comes up with a kit Ringmaster with a mere 15FP and about a 8.5-5 prop. Full paint job, probably weighs around 32-33 ounces. We know this is going to be a dog of the highest order. But, after we got his controls slowed down, it flew very well, better than most Ringmasters. We both take a flight, and it's amazing, this little "underpowered" airplane with the worst of the design characteristics from the late 40's and know to be one of the worst-flying models that is commonly built, flew like a regular airplane and had no problem with a 10 mph breeze.
   It finally clicked. The very next day I went to PECs Hobbies in Mountain view, and what do I find but an OS20FP ABN, $47. The rest is well-documented. Spent a lot of time over the next few years out flying the Skyray 35 (originally built with a Dixon 40FP, then with a bypass-stuffer Fox) with various engines. The first 20FP flight was stunning, back-to-back with the Fox flights. It was like gravity had been turned off, the airplane flew up, down, horizontally at the same speed with me hardly having to help it at all. With the Fox, I could get it through patterns but I was a very accomplished Expert-caliber flier and NATs Top 20 qualifier. Most people would have had little luck with it. Anybody could fly it with the 20FP, it was dead easy.
   ALL of the small engines I tried worked very well, far better than the Fox reference and all of them handled much better than a Fox and gave much better performance than a Fox. My rules (and still the rules to follow if someone wants to repeat it)  - 4" of pitch, no internal modifications or head gaskets, and stock mufflers. The only engines that I tried that didn't work lwere just too big for the airplane, 32's and 36s. They also run much better in most cases than any of the modified/butchered 40's because those mostly ran like Fox 35s on 6" of pitch.
« Reply #7 on: July 30, 2016, 10:22:29 PM »
Heres a frightfully grubby hard used well worn Magnum 25 , with a Fox 25/19 BB C/L intakes carved down to fit the case , seeing you mentioned it . LL~ Way past ten gallons Id think of mainly ' hot stuff' comercial fuel .
in its valiant efforts , sidwinder , with a Nobler Sized 47 Oz. olde Dog . Dead Stock .
Offline Fredvon4
  • Central Texas
« Reply #8 on: July 31, 2016, 07:06:11 AM »
Thank you sir for the back story
My initial interest with model airplanes was in the late 50s when my dad and I (about 4 years old) built a Ring Master while he was posted to Ft Bliss El Paso Tx
Many years later while he was in Viet Nam we lived with Grandma in Oakland Ca where I was high School student playing with model airplanes weekends and after school
I remember my mom taking me to some of the contests in the Bay Area:
San Jose to Sacramento or out near Modesto
I have zero memory of the names of any contestants, clubs, or even the park, school yard or airfields we went to
Seem to remember some flying at Alameda Navel air-station
 I mostly built Mongoose slow combat planes with Enya 35, or McCoy on the nose
The one contest I ever entered was in Hayward or Walnut Creek where in 4th or 5th place I won a Fox 35 and can of fuel
I have been tested for Alzheimer and that is not the problem ----so I am a bit frustrated that I can't seem to remember those 4~5 years with any clarity
Any way
I sincerely appreciate the time all of you guys take to write and post this information
Fred von Gortler IV
Offline Chris Keller
« Reply #9 on: July 31, 2016, 09:43:42 AM »
Love this thread. Im "drinking the koolaid" as well on the 20fps. Ive been able to score abn models on ebay over the past few months from $20 bucks for gently used on up to $55 for NIB. Currently building a few ~400" profiles to put them on (skyray, shark 402). Venturis and needle valve assemblies still available on tower and rcjapan. Cant find the 3oz tank specified so going with the 4oz sullivan slants. 9-4 apcs, check. Only thing left to decide is plugs. Os? Thunderbolt? Merlin?
Offline Fredvon4
  • Central Texas
« Reply #10 on: July 31, 2016, 10:09:06 AM »
Chris I got a few KB-1Ls and FireBalls,  OS 7s and a bunch unknown
One of my three ebay used OSs had a non working plug the others ran fine with the used plug in them
Unless you are competing I tend to think just about any medium to hot long reach plug will be fine
I have a few of the so called preferred plugs for most stunt use, ThunderBolt RC long, that I will save (costly and hard to find) for some day when or if I ever get serious about stunt or combat flying.. but in my beater planes long reach medium seem to work well so far
I have to go back and re-read but I don't think any of the BBTU posts mentioned a plug suggestion... been wrong before so going go look n read
Fred von Gortler IV
Offline Fredvon4
  • Central Texas
« Reply #11 on: July 31, 2016, 10:17:01 AM »
Well there you go...I was wrong...Dirty Dan sez Thunderbolt RC long is the plug to use
Fred von Gortler IV
« Reply #12 on: July 31, 2016, 10:39:39 AM »
So with a run like this is the heat range of the plug as critical as it is on a 2-4 style engine? I know with the foxes i was running i couldn't find a plug that was too hot. The fox stunt olugs that came out that claimed to "fix the burp" were really good but my stash of those are about depleted. In the la 46's i run the stock plug that came with the engines seemed to last a heck of a long time so i think a hot os plug will be my next step.
Online Tim Wescott
« Reply #13 on: July 31, 2016, 02:06:20 PM »
I have a Mangum 35 that came to me on a Fancherized Twister.  It works great on that sized plane with a 4" prop.
« Reply #14 on: July 31, 2016, 04:41:18 PM »
     I haven't found it to be critical at all no matter how you run it, 4-2 or otherwise, on any engine. The check for goodness is if you get an RPM drop when you remove the battery, if no, then it's probably good enough. I haven't been at all careful with the plug selection, I just use the one it comes with, or a recycled Thunderbolt with the element scraped of any accumulated crud that came from my larger engines. Any quaility plug should work, avoid either Fox or Rossi. Fox because the vary wildly from copy to copy, and Rossi because they seem to reliably cause the "cut off like you flipped a switch" problem, in a large range of conditions and systems.
     Glow-Devil, McCoy, Thunderbolt, Enya, OS, etc are a good start. I found the Merlin plugs to run well, but my battery will not attach to them properly. You have to grind the electrode on the Enya to make it work, but there's no reasonable way to grind the Merlins.
« Reply #15 on: July 31, 2016, 09:48:02 PM »
Thanks for the reply - now that you mention it the fox plugs were good - until they quit mid air!
« Reply #16 on: August 02, 2016, 05:26:54 PM »
For "Fredvon4", the Magnum and ASP (both should say "Made in China") are ABC, not ABN. I don't know about the early Magnums, which were made in Taiwan (for Hobby Shack/Hobby People), whether they were chrome or nickel. I've seen them, but never owned one. I rather like the Magnums made in PRC. I've run and flown an XL .25 and XLS .36, and have an ASP .53 on the bench. Not bad engines...a bit like a Fox, in that you need to be a bit careful tightening the screws to avoid binds.
K&B, Thunderbolt, and likely Zinger, RO-Jett, and other brands of glowplugs are all made by Ohlsson Corporation, the remains of the old "O&R" engine mfg. I don't know what other brands they make, but I'd like to know. If anybody has the 411 on that, please post it...maybe pin it to the top of the forum? I've got enough Thunderbolt idlebar and 4-cycle glowplugs to last me at least 10 more years. I have a very poor opinion of Fox glowplugs, so if you are out of those, I'd suggest a celebration. There's nothing wrong with OS or Enya glowplugs, but they're a bit pricey.  H^^ Steve
Offline Fredvon4
  • Central Texas
« Reply #17 on: August 03, 2016, 09:15:02 AM »
Typing too fast and failure to proof read before hitting post.. of course you re correct on the ASP/Magnums not being ABN
On glow plugs:
Since I returned to aero modeling I have found several lists here and there on glow plugs and heat ranges / configurations : short, long, idle bar etc
But in each case a dated list, and not much info on currently produced Glow plugs, nor any good info on what plug was the new engine sold with originally
One of my problems is having a BUNCH of glow plugs from my growing collection (55 different ) of used and older NIB engine acquisitions. With  no way to know what plug was supposed to be in the engine vs what it was sent to me with
Example a NIB never run Super Tigre Italian G-21 .35 with installed glow plug
Having too broad a range of glow engines...many very old 50s~60s, and several somewhat newer from the mid 70s to early 2000s and then a few current production like Evo .36 is a PITA to keep parts and glow plugs cataloged ready for eventual use on a model
While researching each engine for set up hints, I ended up with a very wide array of 2 or 3 each of 9 different new glow plugs and some thirty odd "came in the engine" plugs with no easy way to determine one from another (the used plugs)
This created a massive problem sorting, cataloging, and keeping the right plug with a specific engine
I do wish decades ago the plug manufacturers had discussed and agreed on some standard convention for marking the plug in some way
Just seems a shame to have 20~30 used plugs with no good way to know what heat range it may be
Fred von Gortler IV
Offline Jim Carter
« Reply #18 on: August 03, 2016, 10:25:03 AM »
Hi Fred!  Please don't think me being rude, it's not my intention by any means.  BUT .... I think you may be overthinking this plug thing a bit or maybe I'm just a really lousy pilot!!  Pick an engine and just screw in a plug and light it up!  If the engine runs .... great!!  If not .... pull it out, stick in another one and give it a go.  Eventually you will find one that will work just fine and the one's you've tried can be tried/used in a different engine and by process of elimination something will work and bring a smile to your face ;D!!
Offline Fredvon4
  • Central Texas
« Reply #19 on: August 03, 2016, 10:52:12 AM »
Actually Jim...that is not rude at all. Sometimes I have trouble forcing my OCD to the rear of the brain let me eventually conclude exactly what you suggest....
And because I am sport pilot with meager skills I decided to not worry if or when some engine flames out in flight
That said, there are a few models I wanted to get the power configurations as simple and problem free from the get go.
Thankfully all here have provided enough info to select a good engine, preferred fuel tank, preferred fuel mix, reliable glow plug, range of props to work with and much more
I suppose if I lived in a area with many Control line fliers I would have learned most of this at the airfield or a buddies work shop
BTW just after my post above about glow plugs, I went to another web forum and a Banner ad asked me if I want a New Gold Plated OS 80 glow plug
Gotta love the ad bots watching what I post about and offering to take my money....grin
http://www.osengines.com/glowplugs/index.html
Fred von Gortler IV
Offline Phil Spillman
« Reply #20 on: August 03, 2016, 09:11:01 PM »
Hi Friends and Viewers, Just a little background re: Phil Spillman: Age 78, years flying UC 67, focus: mostly Sport but have been forcibly moved to Expert even for local contests for 8 years now, and finally just love to fly Ringmasters and P-51/F-51 Mustangs with almost any power plant! Most astounding discovery was how much better the "Old Sterling" profiles flew with: FP 25,20, LA .25 than they ever had before! Didn't know all the scientific reasons why but the realities were astounding to me! I did find out about the 9 X 4 APc's on my own. I have also experimented with 9 X 5's and 10 X 4's. they all help in different situations and locals. Try also wood and glass filled plastics.
My most recent plugs of choice have been the Sig 003'S with idle bars. Previously chose Thunder Bolts long with idle bars. Add extra castor oil to engines using iron pistons and sleeves; not as much oil for ABC's and ABN'S more in the ABN's if need be. the need Will appear once the engine over heats!
Just my $00.22.5 cents worth!
Phil Spillman
Phil Spillman
