  • June 20, 2025, 04:15:24 PM
Author Topic: VF and PA not quite interchangeable?  (Read 828 times)
Offline Steve Fitton
« on: May 20, 2013, 01:36:53 PM »
The VF is shorter in terms of overall length?  Thats what I am finding comparing the VF to a PA-65....
Re: VF and PA not quite interchangeable?
« Reply #1 on: May 20, 2013, 02:50:18 PM »
Many times, an engine that comes with a collet mounted prop driver (like most ST's, for example) can be adjusted with a washer behind the collet, or even by shortening the collet a bit on the back side. The later may require some rework on the back of the prop driver, or not.
I have a VF and some PA's and frankly don't know how the prop driver is secured on any of them, but I'd almost bet on use of a collet...clearly the best way, IMO.   H^^ Steve
