  • June 17, 2025, 02:15:05 AM
Author Topic: Old Fox 19  (Read 1259 times)
Offline Richard Logston
Old Fox 19
« on: September 15, 2015, 01:54:05 PM »
I have what appears to be 70's vintage Fox engine with an RC carb. I have removed the carb and made an aluminum inset into the intake. My question is what type and size needle valve would be best for this conversion to C/L function. Richard
Re: Old Fox 19
« Reply #1 on: September 15, 2015, 03:32:06 PM »
You'll get lots of suggestions on this one.  The top three will be an ST-style NVA (you can get new ones from two or three vendors here -- at the risk of leaving someone out I'd check with Randy Smith, Jim Lee, and Stunthanger Hobbies), an OS LA-25 NVA (Tower Hobbies), or go see if Fox has one for their CL version of the same engine (check the Fox website).
The ST, at 0.156" diameter, may be a bit big for your Fox engine.  I think my first choice would be to see if Fox made a CL version of that engine, then see if they'll sell you a needle valve assembly.
Re: Old Fox 19
« Reply #2 on: September 15, 2015, 04:06:41 PM »
Thanks for your informative reply. Richard
