  • July 16, 2025, 11:13:26 PM
Author Topic: Excess Fuel Consumption  (Read 1859 times)
Offline petermick
« on: August 16, 2013, 12:32:42 PM »
Hi All,
The ongoing saga of setting up my Oriental I believe is nearing an end.  I originally was running an LA 46 with the stock muffler, stock needle valve and a BYO 11-4 prop on a uniflow setup w/o muffler pressure.  I could easily complete the pattern on 3 1/2 oz of Sig 5% nitro 20% caster fuel.  The other day I replaced the stock muffler with a tongue muffler and on a lark went to a Bolly 12.5 x 5.5 carbon fiber prop.  I assumed the prop would be too much for this engine.  Not so.  It took off like a shot and was giving lap times of 5.20 seconds on 62 foot lines.  It went wherever I pointed it without any loss of line tension.  My first flight was on four oz of fuel.  The plane ran out of fuel in the middle of the overhead eight.  On the next flight I filled the tank to its 4.5 oz capacity and ran out of fuel in the cloverleaf.
I do not have room to put in a 5 oz tank unless I can get a custom made tank.  My tank size is 1 inch tall, 4 1/2 inches long, 2 inches wide.  I have excess space to add 3/8 inch to the height of the tank.  I am willing to purchase such a tank if anyone can make a recommendation to someone who can make one.
If anyone has any other suggestions to solve this problem I certainly would appreciate hearing from you.
Peter Mick
Re: Excess Fuel Consumption
« Reply #1 on: August 16, 2013, 02:40:44 PM »
Hi Peter,
You might be OK with a slight reduction in venturi size, or adding layers of pantyhose like a filter over the venturi.
Another idea would be to trim a 1/4" off each tip of the prop.
BIG Bear
RNMM/AMM
Offline Gerald Arana
« Reply #2 on: August 18, 2013, 09:54:20 AM »
Hi Peter Mick
I run LA 46's too. I use an OS 762 muffler, LA 25 Venturi, stock NV, two head shims, 11X4 Vess, 10-22, 50/50 and use about 3-1/2 oz's for the pattern.
This is with a Vector 40 (ARF) size ship running a rich 2,2,2 stroke and I have NO problem with power.
I'd suggest going back to your first set up and getting rid of that @#%$*&@#$ tongue muffler. ( I don't like TM's) But that is just my HO...........well maybe not so H. H^^
Jerry
Offline Kim Mortimore
« Reply #3 on: August 19, 2013, 08:05:29 PM »
The ability of the LA 46 to drive that much prop is yet another addition to the large pile of evidence that the LA 46 is a superior low-cost stunt engine.  Reducing the effective choke area with a few layers of nylon stocking or trying a smaller venturi would be the easiest experiment for extending the run time.  It's possible, however, that the engine may need the full choke area to drive the big prop with maximum reliability.  You don't need a large increase in run time to complete the pattern and a few extra laps.  The carbon fiber Bolly could be repitched down a bit, say to 5.25, increasing the rpm for the same lap time, thus increasing run time.  Obviously a prop pitch gauge is required to do the repitching.  Do you happen to have another Bolly with lower pitch?  Did you tach the engine with the big prop before launch?  If so, what was your takeoff rpm?
Kim Mortimore
Santa Clara, CA
« Reply #4 on: August 21, 2013, 11:39:58 PM »
More load increases fuel consumption, as does more nitro, more air flow (i.e., bigger venturi or muffler outlet) or higher oil %.  While the Bolly might well work better than the BY&0 11-4, I think you should keep looking for a more suitable propeller. Perhaps a TT 11-4.5, an APC 11.5 x 4 or 12.25 x 3.75? Remember, it's not about how it looks or how heavy it is, but how well it works,  how likely you are to break it, and can you replace it if/when you do break it.   H^^ Steve
John Leidle
« Reply #5 on: August 24, 2013, 08:16:25 AM »
   I found some tanks on Eric Rules site that are thicker & they work great for me   3"long 2" wide & 1 .35" thick  They might be combat tanks so I just peplum them .
Offline Garf
    • Hangar Flying
« Reply #6 on: September 08, 2013, 08:04:47 PM »
On my Fronkensteen 4, I use an OS LA 46 and a Tower 40 Muffler with an XOAR 12 X 4 prop. It uses 3.75 oz of fuel, 5% nitro, 15% castor, 5% Klotz.
Offline Michael Massey
« Reply #7 on: September 13, 2013, 09:21:38 PM »
Interesting timing on your problem.  I just finished a scratch built "Green Box" Nobler and put an LA46 in it.  For the sake of heavy front end I put a Randy Smith LA 46 CNC tube muffler on it.  It weighs 1 oz.  A great savings over the 2+ oz. stock muffler.
I ran out of fuel on the overhead 8.  Next filled my 6 oz tank with 5.5 oz.  Was barely able to complete the Clover leaf but not the 2 laps after.  This engine had been in a profile Pathfinder and I always used 5 oz with a very comfortable margin for the pattern.  After a lot of "horsing around" with set up, I went back to the stock, albeit heavy, muffler.  I am now back to a full pattern with plenty of comfort for completion on 5 oz fuel.  Guess I need to learn a lot more about exhaust systems.
Eagle Point, Oregon
AMA 914713
« Reply #8 on: September 14, 2013, 09:24:15 AM »
Your putting out more power with my muffler, are you running high nitro ?, you can do several things, first drop to 5% nitro, that engine with my muffler setup make huge power for a Nobler, you could also add 1 head shim ,you should check to see what size venturie is in the motor, and what NVAs is in it, if it is the stock size it will use more fuel ,as it is a 20 size Spraybar and about .30 thou smaller diameter than the normal size bar , you should be able to do a pattern with 5 or so ounces
« Reply #9 on: September 14, 2013, 12:33:20 PM »
Thanks for the feedback Randy.  I just finished the plane and within the next month, there are two contests I am attending.  The Meet 'n Meat (Woodland, CA) and the Golden State (Madera, CA).  Currently, because of flying site issues, I can only get out once a week for about 4 to 6 flights.  So not a lot of time to "fuss" with the adjustments to the engine run.  I feel it is safer to get what practice I can with the current set up then after the events, try to get back to the light muffler.  I will certainly try your suggestions and appreciate the feedback.
Eagle Point, Oregon
AMA 914713
« Reply #10 on: September 14, 2013, 05:55:30 PM »
Randy, guess my answer did not really answer your questions.  So I'll try to do better.
I started out with Sig 10% Nitro and 20% (half Castor and half synthetic) fuel which is my typical.  I have only the one stock head shim, running an oversize venturi (.297) which I changed out with a stock venturi (.282 or thereabouts), with both your NVA and an ST51 NVA.  As you can gather, I was trying different variables to try to get at the problem.  Once I get through the contests I will try your suggestions with your muffler once again.
Thanks again.
Eagle Point, Oregon
AMA 914713
