  • June 26, 2025, 09:07:23 AM
Author Topic: Evolution Engines  (Read 900 times)
Offline Roger Hyatt 3rd
  • The Rolla Raptors
Evolution Engines
« on: December 10, 2011, 08:09:03 PM »
Evolution Engines are they good bad or what? I am considering trying them but have not heard much about them.
Roger Hyatt 3rd
AMA 995656
Offline Balsa Butcher
  • High Desert Flier
Re: Evolution Engines
« Reply #1 on: December 11, 2011, 09:41:53 AM »
They are good. Do a search and you will find a lot of information about them on this forum.  8)
Pete Cunha
Sacramento CA.
AMA 57499
Offline Joseph Lijoi
« Reply #2 on: December 12, 2011, 11:21:58 AM »
I think they are very good.  I have no experience with the 60 but have seen good reviews of it.  For the 36 many replace the needle valve but this may be because of weak noses that cause vibration.  The engine is a smooth runner.  Repalcement parts are cheap.  I run them in on a bench but this may not be neccessary.  If you want to get a new needle valve assembly try the OS part #21181902.  This is the 1A,15 needle valve assemby (about 10 bucks).  This screws right into the stock venturi, but use some hi temp form a gasket.  Don't use the large venturi for stunt.  There is a lot of info out there.  Good Luck.
  • The Rolla Raptors
« Reply #3 on: March 06, 2012, 10:29:43 PM »
Ok we bought a Evo 36 and 60 and so far we are very pleased with them. Will update as time gos on.
Roger Hyatt 3rd
AMA 995656
Tags: 60
