After having pains with the Oriental Plus and getting a decent engine run for an entire season, I decided I have had enough of plastic tanks. It leaked like a siv at the end of the flying year last year which made me refinish the nose over the winter, now the shim is off by A LOT and no matter where I move the tank up, down, or rotate it, the shim doesn't change at all. Also today, I landed and the thing started spitting up fuel through the pickup and now the nose is discolored again (sigh).
So now we decided that, in order for this to be a decent backup ship for the NATS, should anything happen to the TP, I need a good motor run, so starting tomorrow we're going to cut into the airplane, install a tank floor, cut into the wing about a 1/2" to accomodate a 6 ounce magnum tank. We'll see what happens after that.
Has anybody else had plastic tank issues like what I just described?
