  • June 20, 2025, 12:54:37 PM
Author Topic: ST60 NVA internal geometry  (Read 1225 times)
Offline Matt Piatkowski
« on: October 13, 2016, 07:33:40 AM »
Hello,
I am looking for the drawing of the ST60 NVA showing the internal geometry with dimensions.
Specifically, I am trying to understand WHAT stops the needle while it is being rotated CW by hand to the very end.
It feels like hard stop. Maybe it is simply the needle thread hitting the non threaded part of the spray bar hole?
Matt
Re: ST60 NVA internal geometry
« Reply #1 on: October 13, 2016, 08:50:32 AM »
Hello,
Matt
   It's the needle seating itself in the orfice.
« Reply #2 on: October 16, 2016, 03:55:10 PM »
I would expect that the orfice would be formed by the point of the tap drill. I guess if you want to split one down the center, you could confirm that. Perhaps grind or file away to the centerline or close? No, I wouldn't bother.
However, I had a ST "Clone" assembly that didn't shut off completely, and in fact did not appear to bring a Magnum XL .25 to full peak because the NV wasn't threaded far enough. Sort of odd to run the engine with the NV cranked in as far as it would go.
I put that NV Assy. into a .46LA and it worked fine, except that I couldn't shut off the fuel completely...which is perfectly fine with me.  H^^ Steve
