  • July 10, 2025, 03:22:30 PM
Author Topic: Evolution 36 conversion  (Read 4036 times)
Offline dennis lipsett
« on: December 06, 2011, 09:01:36 AM »
There have been a few threads on the Evolution 36 and in particular it's venturi and fuel delivery system. Admitidly it is a weak spot on a better then most people have given it credit  for engine.
 I'd wanted to convert one for awhile and called around and of course called Jim Lee. He had already done it and was happy with it. His venturi and  one of Randy's NVA's properly sleeved for the conversion.So for viewing pleasure, here is how a properly converted Evolution 36 should look like.
My thanks to Jim  Lee and Randy Smith for this conversion.
Dennis
Offline Balsa Butcher
  • High Desert Flier
Re: Evolution 36 conversion
« Reply #1 on: December 06, 2011, 09:23:30 AM »
Thanks Dennis, I exchanged my Evo NVA assembly for an OS remote NVA and it works all right but these pics may inspire me to take it to the next level.  8)
Pete Cunha
Sacramento CA.
AMA 57499
Offline Joseph Lijoi
« Reply #2 on: December 06, 2011, 01:02:17 PM »
Dennis-
How did this work out?  Looks really good.  I got a venturi for the Evo 36 that had a through hole in it from Jim and it worked really well.  I also have put a OS part #21181902 1A,15 NVA in the stock small venturi and it also works really well.  The remote didn't work for me, but the plane had a weak nose.
I really like my Evo.  I got three venturis from Jim.  I never had time try the large one.  The smallest .280 venturi really turns a 10-5 at a fat four cycle at around 10,000.  With the biggest venturi he sent I think it will proably turn an 11 1/4-4 really well, which is people are using an the 46 LA.  This engine seems more powerful than the Brodak 40 even though it's a bit heavier.
I agree that this engine is better than people think.  Parts are really cheap too.  Don't ask me how i know this.
Offline bill bischoff
« Reply #3 on: December 07, 2011, 09:35:43 PM »
I just drilled all the way through the stock (medium) venturi fuel fitting hole, filed some flat spots on the sides, and used a Supertigre NVA. Might not be the exact right spraybar height for a built up fuse installation, but it works great on a profile with a 4 oz Hayes slimline plastic tank mounted on its side.
« Reply #4 on: December 08, 2011, 03:47:44 PM »
Thanks, Dennis!
Since I have not seen the "stock" set up, I am not aware of what has been changed.  :o  :(
Big Bear
  • High Desert Flier
« Reply #5 on: December 11, 2011, 10:29:08 AM »
Hi Bill, stock set-up is standard remote-NV configuration that you see on OS LA engines and others. 8)
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #6 on: December 11, 2011, 12:06:50 PM »
Thanks, Pete.  AS I thought about it, I kinda pictured that scenario.
Dennis, is the venturi you are using a "sprinkler"?
« Reply #7 on: December 11, 2011, 02:02:03 PM »
Bill,
Yes it is.
Dennis
Offline YakNine
« Reply #8 on: June 29, 2012, 07:10:23 PM »
Hey Dennis, have you gotten any flite time on your conversion yet was wondering how it was working. T.J.
AMA 85135        GSCB
« Reply #9 on: June 29, 2012, 07:31:56 PM »
Quote from: Bill Little on December 11, 2011, 02:06:50 PM
Bill,
Yes it is.
Dennis
Hi Dennis
Does this have multiple holes all the way around the venturie for fuel to sprinkle out (sprinkler)  or does it have 1 hole for the fuel to come out of (true venturie) ?
« Reply #10 on: June 29, 2012, 07:39:10 PM »
     A venturi can have either single or multiple fuel inlets and still be "true".
« Reply #11 on: June 29, 2012, 07:46:17 PM »
True enough ,But not a sprinkler, as it has been known for decades in Model engines, this came mainly from the 360 degree holes of the Super Tiger sprinkler venturie.
If it has 1 hole it isn't a sprinkler
« Last Edit: June 29, 2012, 08:38:28 PM by RandySmith »
« Reply #12 on: June 29, 2012, 07:48:13 PM »
They also work much much better with 1 hole, rather than the many holes around the perimeter, I know this from test after test after test on several motors.
Offline kenneth cook
« Reply #13 on: June 29, 2012, 09:02:28 PM »
              Hi Dennis, the last we spoke I was asking about the possibility of using the Evo in speed limit combat. Well sure enough Brad Lapointe was using one for WWII speed limit combat. This engine has ba!!& . His was swinging a 12" cutter and just going around at a great pace. The engine just doesn't miss a beat and real friendly. I knew this would work. Brad was smiling away and we were just in awe over how this engine runs. Certainly a good option and it certainly appears that parts don't break the bank as well. Ken
« Reply #14 on: June 29, 2012, 09:43:21 PM »
Randy, It is not the tiger 360 type but a single point. As Brett said it is still a true sprinkler. I can't remember the id of the venturi right now and thats pretty bad seeing as I did 2 of them.I'll check and get back. They run perfectly with a 2/2 break and when broken in are not bad on fuel. I have an additional engine fitted with an Irvine venturi with a banjo type NVA that also runs well. It has a slightly smaller hole and delivers really well controlled power. The spray bar used with Jim Lee's venturi has to be sleeved to fit the oversized holes for the cinch bolt. The venturi unlike most  has a relatively small hole in it. Proper alignment is required for the 3 pieces but easy to do. Hopefully the next shipment will have these conversions done. This will make the engine fully capable out of the box.
« Reply #15 on: June 29, 2012, 10:18:21 PM »
Hi Dennis
Looks  very good, much better than the stock setup. Now all they need do is make the Motors with a venturie similar to this in future runs, I think everyone will be much happier. Also What I ask was ,it a sprinkler, or venturie with the standard 1 hole, It is a venturie but it is not a sprinkler. That was also what Brett was saying.
Have you tried to run this in a 4 cycle/ 2cycle yet? if so how does it transition? would be interesting if it will do both. I have some people running a 4/2 HI RPM run with some of the ones I sold them.
Offline Douglas Ames
« Reply #16 on: June 30, 2012, 06:00:33 AM »
aka - Annular Discharge    ...which is the most efficient form of a booster venturi in a carburetor.
AMA 656546
Offline YakNine
« Reply #17 on: June 30, 2012, 09:08:09 AM »
Are the new ones available yet horizon still shows the old one on their web site
AMA 85135        GSCB
« Reply #18 on: June 30, 2012, 09:59:54 AM »
Which is apples compared to oranges, we don't run carburetors, nor do we have booster venturies inside of venturies, and if we did there would still be 1 main feed to the inside booster venturie.
Although this would make for a very interesting exercise to make a venturie with a booster inside of it.  Someone needs to take on that chore and report back to us
There were many downsides to the Super Tiger Sprinkler venturie
1 was the machined step halfway down, this worked but not nearly as well as a real , or conventional venturie made with the  proper angles
2 was the very tiny holes you needed to keep the fuel from dribbling..if the holes are made larger the fuel does not come out of the multiple holes very well, same thing happens if you make a main hole way too large.  The same thing happens when people drill out true venturies into straight tubes...they loose the fuel feed pressure and the fuel will dribble out of the side.
3 The tiny holes needed to use in the sprinkler would stop up much much easier than 1 larger hole, especially if you used castor fuel.
4  Super Tiger used, and you needed a complete ditch cut all the way around the outside of the venturie for the fuel to flow all the way around in order to feed the 360 degree holes, this got mix with air near the end of the tank and caused many engines to surge and cut on and off, you can fix this by blocking off that area and using only 1 or 2 holes close to the fuel feed (spray bar), this would stop the surging caused by the air bubbles. You could then jb weld or turn a 3/4 moon shaped piece to fill the ditch in the ST venturie.
The st venturie was better after this mod, you could use 2 holes if wanted in this configuration and you could also just use a smaller slit to connect the 2 feed holes, if you wanted to use 2, if this was used it is best to center the 2 holes between the sprat bar feed hole.
We made many adjustable venturies with 3 and 4 feedholes similar to the sprinkler one, but they were differant because they had a much smaller area inside to feed the holes with fuel. These worked OK  but did not work better than a standard true venturie.
« Last Edit: June 30, 2012, 01:13:30 PM by RandySmith »
Offline Chris Wilson
« Reply #19 on: July 01, 2012, 08:45:42 PM »
Thanks for that reply Randy, it answers a lot of questions that are kicked around the forums from time to time.
MAAA AUS 73427
