Engine basics => Engine set up tips => Topic started by: David Ruff on March 13, 2015, 02:54:09 AM
I have two new Evo 36 CL engines with the remote NVA.
What do I need to convert to standard front NVA on the venturi?
I have OS NVAs that will thread into one side and make them front Needle, that works well, also Jim Lee makes adapters that hold a ST or PA NVA in the front hold down hole either works
Randy..which OS NVA do I need. I will order..
They are the 2a OR 3a RC needle assemblies, they just screw into the small EVO venturie
Randy..received the NVAs today. Thanks. Will let you know how it works.
FWIW: If you haven't found out yet, Evo 36 (and 60s) don't like castor oil. Run it on regular R/C fuel or even full synthetic. For the 36, high rpm, low pitch is the way to go. Lots of power however don't expect a Fox 35 type run. 8)
