  • June 19, 2025, 10:47:57 AM
Author Topic: Evo woe - NO - - Evo go!!!  (Read 801 times)
Offline Ralph Wenzel (d)
« on: October 12, 2008, 08:58:54 PM »
Brett Buck to the rescue. He said to get rid of the muffler for a while at first. Did three short runs on the new Evo that way, then used the tongue muffler. Still not an easy start, but better. And it'll get mo' better as I learn what makes the engine happy. This thing has more pinch at TDC than any engine I've ever run! It even squeaks when I flip it over wet.
Ralph
Ralph Wenzel
AMA 495785 League City, TX
Offline Balsa Butcher
  • High Desert Flier
Re: Evo woe - NO - - Evo go!!!
« Reply #1 on: October 12, 2008, 10:03:23 PM »
When in the too much fuel/squeaky piston mode try setting the prop against compression then slapping it down against the direction of rotation. Some call it a "bump" start.  Takes a little technique but works well with engines that exhibit this characteristic. This is probably better than trying to force the prop through when it the prop is pinching up top.  I have found it works well with my Evo .36.
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #2 on: October 13, 2008, 06:15:56 AM »
Hi Pete,
I start all my 4-strokes the way you suggest. I tried it with the Evo, but no go. The "back bump" might have worked better had I not been using a wood 9-5 prop. Something heavier, like an APC guillotine should work better . . .
Ralph
Ralph Wenzel
  • High Desert Flier
« Reply #3 on: October 13, 2008, 09:14:43 AM »
Point taken - I use an 11x4 when I use that method.  It works for me but not 100% of the time. I also have noticed that I usually do not get a pre-start "bump" when turning the prop prior to engine start...it may just be my technique but it does make it a little more difficult to determine when the engine is ready to go.
Pete Cunha
Sacramento CA.
AMA 57499
Offline Rob Killick
« Reply #4 on: October 13, 2008, 02:01:16 PM »
Hi  Ralph ,
Glad to hear your Evo does start and run  y1
I hope your flipping arm is okay ?
Rob Killick
Rob Killick , MAAC 33300
