  • July 26, 2025, 06:20:56 PM
Author Topic: EVO 60 : User's Views ?  (Read 2038 times)
Offline Robin_Holden
« on: July 16, 2012, 12:10:37 AM »
Hello fellas from S.W.France.
I'm still delighted with my Evo 60.
It's been around for a while now so can anyone else share their experience with this fine engine please  ?
Props' , fuel , launch rpm , tongue or standard muffler etc.
Much obliged for any contributions ,
Robin.
Offline Balsa Butcher
  • High Desert Flier
Re: EVO 60 : User's Views ?
« Reply #1 on: July 16, 2012, 04:22:27 PM »
Hi Robin, no updates since I reported my setup in your EVO 60 thread that was posted in February of this year. Still a great engine IMHO. 8)
Pete Cunha
Sacramento CA.
AMA 57499
Walter Hicks
« Reply #2 on: July 18, 2012, 06:50:06 PM »
The Evo 60 is a great engine. Easy to start, smooth ,well mannered. For the $ it is excellent. Do pay attention to the
fuel choices. They run excellent when you use the correct fuel. Mine is on a friends way overweight Pathfinder.
No problems so far. Nice easy not to harsh 2-4 break also.
« Reply #3 on: July 19, 2012, 08:11:25 PM »
Hi Walter,
Have you tached it at launch?  Just looking for a ball park number for launch and prop selection.
Thanks!
Walter Hicks
« Reply #4 on: July 20, 2012, 06:18:08 PM »
Hi Bill , it has been a while I am thinking 8200 . Very, Very user friendly. Prop Rev up 12x6 ? Sorry I now have the '
engine back with me as I will be using it on another project.
  • High Desert Flier
« Reply #5 on: July 20, 2012, 06:29:54 PM »
I'm going with 8800 with an RSM 12x5.5. I think that would be a good combo to start with...and a prop that is actually in production and costs less than $10.00 - how often does that happen?  ;D
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #6 on: July 20, 2012, 07:40:29 PM »
Would GMA 10/22 work in the Evo?
  • High Desert Flier
« Reply #7 on: July 20, 2012, 09:25:46 PM »
I have used it however it did not run well with that blend, sort of "blubbery", not a clean run. Possible too much castor. I found it ran well on Omega 10% (that's their castor/syn blend, the pink stuff) or standard Powermaster 10% R/C fuel. I add one ounce of Randy's "Aero Oil" to each regardless. It is in a plane that is not flown much however I was pleased with the runs I was getting with those fuels and plan to use it in another project. 8)
Pete Cunha
Sacramento CA.
AMA 57499
Offline dennis lipsett
« Reply #8 on: July 20, 2012, 11:19:53 PM »
It's a hard sell trying to get C/l flyers to use less then 20/22% oil and half of it being castor. The Omega pink is actually the 2nd choice. They recommend the cool power green at 16% oil
« Reply #9 on: July 21, 2012, 12:19:14 PM »
The Rustler /40 and the ABC converted ST/46 both run better on Omega.
« Reply #10 on: July 21, 2012, 01:29:38 PM »
If you feel that you have to have more castor, you could try Powermaster 10/17 and see if you like it. I use it a lot for R/C use.
Dennis
