  • June 24, 2025, 03:05:57 AM
Author Topic: Fox 25 R/C  (Read 952 times)
Offline Bootlegger
Fox 25 R/C
« on: March 19, 2013, 05:19:02 AM »
  Guy's a friend has a Fox 25 with carb, the barrel is stuck in the partially open/closed position. This engine has the bolt on carb, so it must be a later engine, it appears to be run very lightly.
 We currently have it soaking in brake cleaner to free up the carb.
 What size venturi should we install, and where can we get one?
       Thanks a lot...
8th Air Force Veteran
Gil Causey
AMA# 6964
Re: Fox 25 R/C
« Reply #1 on: March 19, 2013, 08:26:00 AM »
Call FOX, they may have them in stock
Offline Duke.Johnson
Re: Fox 25 R/C
« Reply #2 on: March 19, 2013, 08:52:37 AM »
Bootlegger
If you find it, let me know.  I have this engine in a plane and would like to get rid of the two needle carb.
Offline Bootlegger
Re: Fox 25 R/C
« Reply #3 on: March 19, 2013, 09:12:25 AM »
  Randy,thanks for the heads up at Fox, will do.
  Duke this isn't a two needle set up, although I have seen them. Have you tried running it with only one needle?
 You might try that and see if it will run, then try running it on the other needle. One is probably low and the other high speed.
  Of course your mileage may vary...
Gil Causey
AMA# 6964
Re: Fox 25 R/C
« Reply #4 on: March 19, 2013, 12:10:26 PM »
It runs ok with the high and low speed needles, it's just a pain to adjust the needle on the bottom when the weather or whatever changes.  Other than that it holds the setting pretty well.  I would like to put the bolt on C/L ventri on to make things easier.
Re: Fox 25 R/C
« Reply #5 on: April 02, 2013, 07:02:44 PM »
You can get the intake & NVA from FOX for the one like the one here , still .
