Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
June 17, 2025, 12:24:48 PM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
EVO 60 Engine
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: EVO 60 Engine (Read 1502 times)
Bootlegger
22 supporter
Trade Count:
0
Admiral
EVO 60 Engine
on:
May 30, 2014, 05:14:01 AM »
Is anyone running this engine, and how do you like it, any changes or is it stock?
Sure would like to hear some reports on it.. Thanks a lot...
Logged
8th Air Force Veteran
Gil Causey
AMA# 6964
Balsa Butcher
24 supporter
Trade Count:
0
Admiral
High Desert Flier
Re: EVO 60 Engine
Reply #1 on:
May 30, 2014, 03:58:10 PM »
Not sure I should even reply here but there is quite a bit on it (including my setup) that can be found thru the search function. Most who have tried them like them. The Massey Bros have great runs with their stock setups. Mine has a hemi-head by Byron Barker and I like it a lot. Small venturi (they come with two), Regular R/C fuel (not GMA-they don't like castor), 12 to 13" prop (I us an RSM 12x5.5, Youtube video features a Bolly 13x4.25) and around 7800-8800 launch rpm. About 5.5 ounces to get thru the pattern. Not a high RPM engine like the Evo .36 they will run a 4x2 break and can haul around 60-70 ounce plane with authority.
Last Edit: May 30, 2014, 05:24:37 PM by Balsa Butcher
Logged
Pete Cunha
Sacramento CA.
AMA 57499
Michael Massey
Trade Count:
0
Commander
Re: EVO 60 Engine
Reply #2 on:
May 31, 2014, 02:46:35 PM »
See Consider an Evo 60 just above. I reposted it for you.
Logged
Eagle Point, Oregon
AMA 914713
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
EVO 60 Engine
