  • July 14, 2025, 08:05:44 AM
Author Topic: Evo 60 : Any Feedback yet ?  (Read 1822 times)
Offline Robin_Holden
« on: February 07, 2012, 01:38:21 AM »
The Evo 60 has been around for a while so , any feedback yet fellas  ?
I'm VERY happy with mine , can't fault it !
Appreciate any comments ,
Regards from a 'snowy' S.W.France,
Robin.
Re: Evo 60 : Any Feedback yet ?
« Reply #1 on: February 07, 2012, 03:38:07 PM »
Hi Robin,
I did a quick search and found the following.  Should give you some information.
http://stunthanger.com/smf/index.php?action=search2
BILL
Offline Roger Hyatt 3rd
  • The Rolla Raptors
« Reply #2 on: March 06, 2012, 10:32:16 PM »
Iwe just bought the 36 and 60 and are very pleased with them so far.
Roger Hyatt 3rd
AMA 995656
Offline Balsa Butcher
  • High Desert Flier
« Reply #3 on: April 08, 2012, 10:20:04 AM »
Just an update: Evo 60 two thumbs up. After running it awhile it just keeps getting better. Small venturi, ST NV (probably not necessary, just had one so tried it) One extra head gasket, RSM 12x5.5 prop, Powermaster R/C 10% fuel. (Too much castor oil in GMA 11/11 for this engine). Launch RPM 8700, strong 4/2/4 run. Pulls my 62 ounce 46 size T-Bird with authority. Had to change the name of the plane from ThunderDog back to ThunderBird.  8)
Pete Cunha
Sacramento CA.
AMA 57499
Offline Hoss Cain
« Reply #4 on: April 28, 2012, 12:45:51 AM »
Sounds good. I don't have my flying machine finished yet so would you please advise me what the fuel consumption is with your EVO 60? I will get it on the bench this weekend and will go standard for a while, with small insert. However I am in need of just how big of a tank I will need in the machine. MANY Thanks for any help you can provide.
Horrace Cain
AMA L-93 CD and Leader
Online Bill Hummel
« Reply #5 on: April 28, 2012, 04:36:55 PM »
We've flown the Evo 60 using about 5.5 ounces for the pattern.  A six ounce tank would be appropriate for most
circumstances, I believe.  That's a commercial metal uniflow, with ram air only, no muffler pressure.
ama 72090
Offline Hoss Cain
« Reply #6 on: April 28, 2012, 06:04:23 PM »
Thank You, much much. That sounds very good. I didn't make the tests today but hopefully this week. That gives me plenty room for what I am doing. My tank will be a Tetra Bubbless tank. Having been using them in RC for a while now and the engines run smooth, and dependable, even if flying till it quits. After a few flights I will know just how much to syringe in. (Ihope, I hope, I hope.  :o)
Your information makes me OK as I am using a 7 OZ. tank.
Again, Thank you much for your kind response.
Horrace Cain
Walter Hicks
« Reply #7 on: April 29, 2012, 08:02:44 PM »
Just got back from a contest in which Pete Cunha  flew his 46 size T - Bird with the Evo 60. Ran excellent. His main comment was do not use our common stunt fuel . Use R/C fuel 10/18 or so.  5/18 . It does not like lot of oil. This was in the initial directions from the designer. Very smooth , easy to start,
nice soft 2-4 break . Does not shake like the ST .60. This is an excellent 60 for $139.00. Comes with 2 venturi, and two mufflers, uses inexpensive fuel.
If you do not want to run a pipe or pay $400 for a motor here is a good one
