Engine basics => Engine set up tips => Topic started by: RandySmith on November 29, 2007, 10:54:55 AM
Hello
I have ENYA Products on the way in, These will include All ENYA engines, NVAs, and ENYA Glo PLugs
I will include these on my website and in my new Catolog soon.
Look for some new products including a C|L ENYA 53 4 stroke
Regards
www.aeroproduct.net
This is great news Randy. I helped a flier set up his Enya 61 SX (?, the new one) two weeks ago. I was very impressed with its run characteristics. I forget the details but it held a fairly high speed 4 stroke with a slight break at the appropriate times. Prop was a Bolly Clubman, but I foget the exact size. No tendency to "run away" and about a 3 flip start. Sweet. Pulled his ARF Strega around with ease. 8)
Thats good..will you have any Enya venturi inserts for the older engines..does the Enya 35 5224 and 5225 take the same insert they look to be almost identical..?
Hi Joe
I have new venturies coming along with mufflers and engines,but did not ask about older ones, I will of course be happy to order them If they still have them on th eparts list
Regards
The ENYA engines and parts, Glow Plugs came in today.
I got in both types of 60s CXS Pro and 60-lll Ringed
SS35s
35 lll
29 IV
20S
SS25S
I will have these listed in the price list soon
Regards
On the engines that come with 2 heads..high and regular compression....How do you tell tell the difference..I notice
that there seems to be a difference in the fin height, but don't know if this is the way to tell.
Also..on the older engines with the square venturi..was there any kind of gasket between the insert and the venturi..like an O ring..but of course this is square...I don't remember seeing one, but someone told me absolutely,positively,without a doubt..There was a gasket!! With my memory, I didn't argue..Anyone know?? ???
Joe,
Yes the square venturi uses a thick paper gasket between the venturi and the case
HI Joe
I just got in another large shipment of ENYA parts and Engines, and I did get some of the old square intakes middle and small size. Plus all sizes of NVAs
