  • June 26, 2025, 07:11:04 AM
Author Topic: Enya SS50  (Read 2552 times)
ChrisSarnowski
Enya SS50
« on: May 15, 2012, 06:15:10 AM »
Hi Guys,
Where do I start with prop and launch RPM for an Enya SS50?
I'm guessing maybe 4-pitch, 12-13 inch, and around 9500 RPM?
APC 12.24x3.75
APC 12x4
I have some Zinger 13x5's and also Thunder Tiger 12.5 x 5.5 but I think that is maybe too much pitch?
Chris
Offline Martin Quartim
    • StuntHobby
Re: Enya SS50
« Reply #1 on: May 15, 2012, 09:39:40 AM »
You are on the right track. The APC 12.25x3.75 works well with it. I have friends using the engine with props from 11x4 to a C.F. 12.5x3.75 3 Blade repitched to 4.0~4.5 in a .60 size model.
The prop will depend on your model and weight. I like to setup the prop for the model more so then for the engine. For example I can put the Enya SS50 in a Vector and use a 10" prop, in a Pathfinder a 11~12 prop,  or for the SV-11 a 12~13  prop.
The engine will develop a tremendous amount of power above 9700rpms and can be used in any .60 size model.
If you get into a 4-2-4 situation I recommend adding head shims or reduce the venturi to keep it in 2-2-2. Enya has head shims for the SS50 in two different thickness, the aluminum one is thicker and the copper one thinner.
This is one of the reasons I love the Enya brand, they have all this stuff to help us tune the engine, including several size venturies.
Martin
Offline Chris Wilson
Re: Enya SS50
« Reply #2 on: May 15, 2012, 07:46:19 PM »
Martin
Agreed, and talking to Ken Enya is no big deal either. Wonderful, wonderful mass produced engines.
(You can also run the engine clockwise if you rotate the front housing 90º anticlockwise!)
« Last Edit: May 16, 2012, 05:49:03 PM by Chris Wilson »
MAAA AUS 73427
    • StuntHobby
Re: Enya SS50
« Reply #3 on: May 15, 2012, 08:29:53 PM »
Enya has an optional  Reverse crank for it as well. JXF has a 12x5 reverse prop ( http://www.himodel.com/plane/JXF_12x5_inch_Beechwood_Propeller_Counter_Rotating.html) and Zinger has all sizes.
Martin
ChrisSarnowski
Re: Enya SS50
« Reply #4 on: May 16, 2012, 05:58:32 AM »
Thanks guys for the info. I am putting the SS50 on a 60-size profile based on the SV11.
My flying buddies gave me the model, and the previous engine was an ST 60.
I will pick up some 13x4 props but also try the 12.25x3.75 and 12x4 that I have already.
-Chris
Offline Allan Perret
  • Proverbs
Re: Enya SS50
« Reply #5 on: May 16, 2012, 07:43:45 AM »
Martin
I did not know about reverse cranks being available from Enya.
What other Enya c/l engines do you know of that also have the reverse crank available ?
Allan Perret
AMA 302406
Slidell, Louisiana
Re: Enya SS50
« Reply #6 on: May 16, 2012, 08:10:21 AM »
The Enya 30SS has them , I know that because I have them in stock here
