  • July 27, 2025, 04:44:52 AM
Author Topic: Enya SS 30  (Read 3506 times)
Offline Chris Wilson
Enya SS 30
« on: May 08, 2012, 11:56:23 PM »
Hi all,
 I have just purchased a deceased estate new Enya SS 30 that has been slightly modified for racing (no muffler ears and the venturi has been drilled out) and was wondering if anyone knows if the Enya SS 25 venturi fits into the 30 SS front housing as I do have it available to purchase?
There appears to be two venturi sizes available 7.53mm and 6.95mm and I am running under the assumption that the smaller size would be best as I can always easily enlarge it.
And the muffler, due to the engine barrel now being a wonderfully milled and smooth radius I suppose that I could match that radius on the standard mufflers mounting face and simply strap it in place or I could similarly use a muffler extension to make a tongue setup.
Or if anyone has an Enya SS 30 venturi for sale for stunt use?
Thanks.
MAAA AUS 73427
Offline Steve Thomas
Re: Enya SS 30
« Reply #1 on: May 09, 2012, 05:15:18 AM »
Hi Chris,
The SS25, 30 and 35 share the same case, so the venturis are interchangeable.  Enya sell a variety of Delrin venturis for them (6.5/7.0/7.5 mm) - quite cheap and the service is excellent.  Have a look here: https://cs206.xbit.jp/~w041133/store13/index.php?main_page=index&cPath=3_19
7mm would be a good place to start.  These are excellent and underrated engines IMHO - light, nice handling and not short of power.  (One even powered last year's champion Cowra Plank Racer, and what higher recommendation could there be than that? ;D
As far as the butchery of your case goes, it might be simpler to just get a new one and fit all the other parts to it.  You'd only be up for about $20.  Parts list here: http://www.enya-engine.com/P_list/P_listSS30_E.html
Cheers
Re: Enya SS 30
« Reply #2 on: May 09, 2012, 04:28:15 PM »
Hi Chris,
Cheers
Hey Steve,
                  I appreciate you getting back to me mate and since my original post I have hunted down the common part 6.95mm venturi insert - so we agree on that size as a good starting point.
Case replacement was one option I had not even considered but if I go down that route it will add to the cost of getting a muffler anyway, add the venturi to that and well ............. should have just gone out and bought a whole new engine shouldn't I?
(But bear in mind that this engine was put together by Lance Smith - for those who do not know him he was a VERY good team race engine builder - so I am loathe to pull it apart in case there is some magic contained in the assembly.)
As mufflers are going I am currently eyeing off an old Enya 19 muffler (I need a 35 mm hole spacing for all this to work) that could be scalloped out to suit the radius on the barrel - only going to cost me an hours work and probably my finger prints left behind on the emery paper as well.
Ah the joy of fixing things!
MAAA AUS 73427
Offline GregArdill
Re: Enya SS 30
« Reply #3 on: May 10, 2012, 06:16:09 AM »
What is on the build list for this gem Chris?
If Lance has breathed on it you can probably count on the timing being changed so max the revs on smallish props.
I think something like a Voodoo Combat wing would be ideal for it. It won't bog it down unnecessarily. You can rev the motor like it will like. And it's not to big a build - you won't have to reinvent anything.  ;D
Greg
Re: Enya SS 30
« Reply #4 on: May 10, 2012, 04:43:37 PM »
Hey Greg,
                I (stupidly) thought that this engine would NOT be breathed on because the Enya SS 30 was a rare choice for racing and thus may have been left stock.
So I post contacted the seller, Andrew Nugent, and he honestly doesn't know if there is anything beyond a gas flowed crank in it and openly states that if that is all that has been done the it won't degrade the run qualities no matter what use it is finally put too.
I have it slated down for stunt use but you have got me thinking that just perhaps it is best 'released back into the wild'  and a wing may not be so strange idea after all mate.
Ah, the muffler situation has been sorted, an old OS Max 762 muffler (they were last used in OS FP 35's I think) has been sourced quite cheaply.
It has a good solid mounting stub that can be radiused quite easily and a small strap attached around the barrel to hold it in place.
I also read all about the mods for this muffler from previous replies on this site concerning opening up the tail pipe - again easily done.
Hmmm, combat wing you say?
MAAA AUS 73427
Re: Enya SS 30
« Reply #5 on: May 10, 2012, 05:32:08 PM »
He wouldn't do that, would he Greg?  :D
Chris, I'm just starting on a 'Miss BJ' for an SS30 - it's a fairly simple and attractive profile stunter. I can send you a PDF if you want to go down that route.
Cheers
Re: Enya SS 30
« Reply #6 on: May 10, 2012, 05:41:32 PM »
Cheers
Hah! My wife's initial are B.J. and she is a "fairly simple and attractive profile stunter" that I have already started on.  Not sure that I want go down that route though ........... ::)
(And no, she doesn't follow these forums - Phew!)
The PDF on the other hand would be much appreciated though, cheers.
MAAA AUS 73427
Re: Enya SS 30
« Reply #7 on: May 10, 2012, 08:27:09 PM »
Maybe I should build something else!  :D
Will send PDF when I get home.
Offline GregArdill
Re: Enya SS 30
« Reply #8 on: May 12, 2012, 05:28:36 PM »
Chris,
If you ABSOLUTELY must have a muffler on the beastie, make it a ventolin can one. As light as possible, so the engine doesn't know you're strangling it to death.
Remember it will really want to breathe.
Greg
Re: Enya SS 30
« Reply #9 on: May 14, 2012, 06:01:45 PM »
Up date time, I have shown the engine to Greg (the above poster)and its been confirmed that the ports have been enlarged for racing use so its simply not worth the time and effort to replace the crankcase, venturi insert, liner, crankshaft (although this 'could' be left in) and then custom fit a muffler to it!
So ........ I took the easy way out and went and bought a new one instead as I really liked the look of the one that I had.
Voodoo it is then Greg, unless the B class team race boys want it back? ;D
MAAA AUS 73427
Offline GregArdill
Re: Enya SS 30
« Reply #10 on: June 01, 2012, 05:47:34 AM »
Chris,
Have you got the Voodoo built yet?
Greg
Re: Enya SS 30
« Reply #11 on: June 01, 2012, 09:51:34 PM »
Chris,
Greg
You stirrer, Greg! LL~
Offline GregArdill
Re: Enya SS 30
« Reply #12 on: June 02, 2012, 05:50:35 PM »
I can but try, mate.
G
Re: Enya SS 30
« Reply #13 on: June 03, 2012, 07:59:39 PM »
G
Greg, I have just machined down a muffler to fit the modified barrel, ordered a venturi (now fitted) only to discover the original engine builder has used a very thin non standard spray bar - I think that the standard Enya bar measures 4mm and this one is about 3.
So I am going to order a new bar and take it from there.
MAAA AUS 73427
Offline GregArdill
Re: Enya SS 30
« Reply #14 on: June 04, 2012, 01:23:49 AM »
Just as long as you haven't started building, eh Chris!  >:D
Greg
