  • June 22, 2025, 08:48:46 PM
Author Topic: Enya crankcase-front end compatibility?  (Read 1052 times)
Offline frank mccune
« on: June 02, 2013, 07:37:21 AM »
     Hi:
      I would like to know if the various Enya crankcases and front ends are interchangeable.  I am speaking about the older engines that were plain bearing sport engines.
      I have mixed a .19 and a .35 crankcases and front ends to make engines that appear to run very well.  Will all of these engines parts interchange? If so, which ones will not?
        Tia,
        Frank
Re: Enya crankcase-front end compatibility?
« Reply #1 on: June 02, 2013, 01:36:00 PM »
     Hi:
        Tia,
        Frank
The older  29 and 35 are the  same, the 45 is different, I did not know the 19 was the same part?
Offline Chris Wilson
« Reply #2 on: June 02, 2013, 04:30:04 PM »
Hi Randy,
               I am guessing that 'interchangeability' does not equate to being the same.
MAAA AUS 73427
« Reply #3 on: June 03, 2013, 06:39:28 AM »
       Hi:
        Perhaps I was a bit vague when I suggested that I had swapped .19 and .35 Enya parts.
        I swapped .19 front ends with .19 crankcases and .35 front ends with .35 crankcases.  I hope that nobody thought that I had swapped .19 parts with .35 parts! Lol This prompted my question as to what Enya parts will interchange.
        In any case, I went through my "junk" box and found parts to assemble a complete .19 engine and a complete .35 engine. Bench ran both and they appear to to be running very well!
        Frank
« Reply #4 on: June 03, 2013, 12:29:38 PM »
I don't know a lot about Enya engines, but I thought it very odd that the Mk.V and Mk.VI .19's have different mounting bolt patterns. But unless there was a profound flaw in the lower end/front end of the earlier version, it wouldn't surprise me if they would interchange, either.
Seldom does an engine manufacturer start with a blank sheet of paper, and whether designed in inch or metric, there is a strong tendency to use common bolt circles, bores/strokes, etc. Examples are strange...some ST G.21 .46 parts interchange with Enya .45 parts. Rossi .15/Cox Conquest .15/Taipan 2.5 rear exhaust hybrids abound, etc. A bit more involved were K&B Series '61/ST .29 "Rattler" hybrids, but they worked pretty well for some.  H^^ Steve
