I've always gotten great info and tips lurking around Stunthangar, so thanks to you all for this excellent resource. Inspired by all of that knowledge here's a trick I used to remove a stubborn Wristpin from a ST46.
I began by trying to remove the pin using the ST needle and it wouldn't budge and then repeatedly after the following steps:
I filled up the backside of the piston with carb cleaner and soaked overnight - no joy.
Heated up the backside with blow torch - nothing
Filled up the backside of the piston with PB blaster and soaked overnight - nope
Torch again - nope
Popped it in the oven - Dang! now the wristpin-pad popped out. Now what?
Well here's how I got it out.
- Wrap a small piece of paper towel around a toothpick and soak in acetone and use it to clean out the wrist pin barrel.
- Scuff the inside of the Wristpin barrel with the micro Dremel engraving bit
- Scuff the end of a piece of 1/8" steel wire using the Dremel cut-off tool
- Apply JB weld to the steel wire and stuff it in the wristpin barrel. Remove excess JB weld that oozes out of the barrel using a toothpick
- Allow the JB weld to set for at least 12 hours
- Squirt a shot of PB blaster on the underside of the piston to soak the pin
- Now jiggle the steel wire clockwise and anticlockwise a quarter turn while slowing pulling out the pin
- Voila!
- Now to remove wire from the pin - clamp the wire tightly in a vice and prize off the pin off by leveraging it off the vice with an adjustable wrench
- Voila!
I've attached some pics of the sequence.
I hope you find this useful if you ever happen to need it.
