Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
June 22, 2025, 11:16:22 AM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
OS 40 FP breakin
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: OS 40 FP breakin (Read 1613 times)
Allen Eshleman
Trade Count:
0
Captain
OS 40 FP breakin
on:
March 26, 2012, 07:18:10 PM »
I just got a NIB O.S. 40 FP. It does not have the instruction sheet. What is a proper break-in procedure. I know I've seen it here but I couldn't find it. I have another one and I love it. Thanks in advance.
Logged
Clint Ormosen
2019 supporter
Trade Count:
0
Admiral
Re: OS 40 FP breakin
Reply #1 on:
March 31, 2012, 11:03:53 AM »
I don't know which version you have, but the later ABN engines break in rather quickly. You could probably do it on the airplane. Using fuel that has about 22% oil and about a 9-5 prop, start it up and let it run with it adjusted to a very fast four stroke just barely breaking into the two stroke mode. Then about every 20-30 seconds slightly pinch the fuel line and let the engine break in to a solid two stroke for 10 seconds or so then let the fuel line go. Do those cycles for one or two tanks of fuel and it should be good to go.
Logged
FLOYD CARTER
24 supporter
Trade Count:
0
Admiral
Reply #2 on:
March 31, 2012, 01:11:31 PM »
Clint has the correct procedure. It is better to break in any engine on the test stand. You should use a smaller prop than the one you fly with, in order to unload the engine. Cycling between 4 stroke and 2 stroke is the right thing. Better yet is to let the engine cool completely between several runs. Just make sure it is run-in enough to hold a strong 2-cycle without sagging or getting hot. Then, you can install a 10-5 or 10-6 prop and go flying without worrying about a lean run damaging the engine.
These engines are not fuel-critical. Many use SIG 10-10-10, which is 20% oil with half castor oil and half synthetic.
Logged
AMA #796 SAM #188 LSF #020
Allen Eshleman
Trade Count:
0
Captain
Reply #3 on:
April 02, 2012, 05:25:22 PM »
Thanks Gentlemen,
I appreciate the info. I got the similar recommendations from Randy over the phone. I didn't realize they were that easy to break in.
Allen
Logged
RandySmith
Administrator
Trade Count:
0
Admiral
Welcome to the Stunt Hanger.
Reply #4 on:
April 02, 2012, 07:24:14 PM »
It is better , rather than dropping down from say a 10 x 6 to a 9 x 6 , to use a 11 x 3 or 11x4 prop, this lets the engine turn up faster, doesn;t load quite as much and is much easier to crank and handle than the 9 in prop
Logged
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
OS 40 FP breakin
