  • June 19, 2025, 04:36:00 PM
Author Topic: Enya .15 III Venturi question  (Read 1879 times)
Offline James Holford
« on: June 29, 2016, 05:18:23 PM »
I'm looking for a CL venturi for my Enya .15 IV.  I've been offered one but it's for the Enya .15 III..
 Would the Venturi for the Enya .15 III properly fit the IV?
Jamie Holford
Baton Rouge Bi-Liners
Lafayette, La
AMA #1126767
Offline Dane Martin
  • heli pilot BHOR
Re: Enya .15 III Venturi question
« Reply #1 on: June 29, 2016, 06:19:53 PM »
Hi James!
Yes, they are indeed the same fit. Just like OS, there are different inner diameter venturi's available.
Re:
« Reply #2 on: June 29, 2016, 06:43:09 PM »
Sweet!!!!!!!!
 Gona put this on the Jr Lightning Streak... figure it won't be as much as a bat from hell like a Fox .19 I was gona put lol
Jamie Holford
Lafayette, La
AMA #1126767
Offline Bootlegger
« Reply #3 on: June 29, 2016, 08:23:19 PM »
 Jamie, I built a Jr Flite streak with an os 10 and it flies very well on 48' .012 lines using 7x4 and 7x5 apc props.
  If you get the chance come over here and I'll let you fly it..
8th Air Force Veteran
Gil Causey
AMA# 6964
Re: Re: Enya .15 III Venturi question
« Reply #4 on: June 30, 2016, 04:14:41 AM »
Sounds good!
Jamie Holford
Lafayette, La
AMA #1126767
Offline Bill Johnson
« Reply #5 on: June 30, 2016, 06:49:34 AM »
I've bought several Enya 15 III and IV venturiis from Bobby Brooks off his Ebay store.
http://www.ebay.com/itm/ENYA-15-19-20-C-L-VENTURI-DELRIN-NIP-/222141945342?hash=item33b8b115fe
As you can see in the listing, he has 3 diameter venturiis. I'm using the 6MM and it works very well for stunt flying.
Best Regards,
AMA 350715
