  • June 20, 2025, 09:01:25 AM
Author Topic: H.P. Gold Cup .40 four cycle mystery.  (Read 1189 times)
Offline frank mccune
« on: July 07, 2016, 08:16:36 AM »
      Hello All:
      While flying the above engine I notice that it does not run in a nice 4 cycle mode.  There is no problem with running this engine in a wet 2 cycle mode.  I was wondering if this engine is not designed to run in a 4 cycle mode.  In the four cycle mode, it runs very rough but when leaned out a bit it runs in a very smooth 2 cycle.
      This is not a flying problem but just a question about the HP Gold Cup .40 engine.  This Gold Cup is a joy and pleasure to use.
      Comments?
        Tia,
        Frank McCune
Re: H.P. Gold Cup .40 four cycle mystery.
« Reply #1 on: July 07, 2016, 08:30:15 AM »
      Hello All:
   The stock engine was certainly not intended to run in a 4-stroke. I suspect it would run smoothly in a 4-stroke at a much higher RPM than you would normally use for 4-2 stunt purposes, but I haven't even seen a Gold Cup run since the very early 80's.
« Reply #2 on: July 07, 2016, 01:59:50 PM »
     Hi Brett:
     I think that you got it correct!  This engine loves to operate in a wet 2 cycle.  So, why insist that it operate where it is not happy? Lol.
     I would like to use 11" props but the grass is a bit high for that where I fly.  Perhaps a good 3 bladed prop would be the answer. An 11-4 or an 11-5 prop appears to be a good choice for this engine.
        Be well,
        Frank
