  • July 14, 2025, 12:34:54 AM
Author Topic: Enya 60 XF - CX C´shaft compatibility question.  (Read 1115 times)
Online Manuel Cortes
« on: March 01, 2018, 10:20:18 AM »
Hi all.
I need to know if the crackcase of the Enya 60 XF is a replacement for the Enya 60 CX.
If some guy (Randy probably....) knows that I´ll agree the information.
Thanks in advance and Kind regards from Spain.
Manuel Cortés (PAMPA member again..... ~>)
Online RandySmith
Re: Enya 60 XF - CX C´shaft compatibility question.
« Reply #1 on: March 01, 2018, 03:33:36 PM »
Hi all.
Hi Manuel
I do not have those 2 here  to measure, maybe someone  will and let you know
Offline Brian Hampton
« Reply #2 on: March 01, 2018, 10:10:17 PM »
I've just measured my 60X and 61CX with 60X measurement given first.
Distance between front/rear mounts 20/18mm.
Distance across mount hole centres 52/43
Crankcase width between bearers 43/34
Front mount hole to prop driver 57/53
Bare weight 16.5/12 ounces
Offline Istvan Travnik
« Reply #3 on: March 02, 2018, 03:28:18 AM »
bare weight difference 4.5 ounces...
We used to say this is good to kill a human...  :X
« Reply #4 on: March 02, 2018, 11:07:18 AM »
Hi.
Thanks for your responses. Is not really for me is for a friend....will keep waiting...
Kind regards.
Manuel.
