Engine basics => Engine set up tips => Topic started by: Manuel Cortes on March 01, 2018, 10:20:18 AM
Hi all.
I need to know if the crackcase of the Enya 60 XF is a replacement for the Enya 60 CX.
If some guy (Randy probably....) knows that I´ll agree the information.
Thanks in advance and Kind regards from Spain.
Manuel Cortés (PAMPA member again..... ~>)
Hi all.
Hi Manuel
I do not have those 2 here to measure, maybe someone will and let you know
I've just measured my 60X and 61CX with 60X measurement given first.
Distance between front/rear mounts 20/18mm.
Distance across mount hole centres 52/43
Crankcase width between bearers 43/34
Front mount hole to prop driver 57/53
Bare weight 16.5/12 ounces
bare weight difference 4.5 ounces...
We used to say this is good to kill a human... :X
Hi.
Thanks for your responses. Is not really for me is for a friend....will keep waiting...
Kind regards.
Manuel.
