  • July 06, 2025, 07:11:26 PM
Author Topic: Enya 60 question for Randy  (Read 1610 times)
Offline James Mills
« on: December 03, 2010, 04:36:32 PM »
Randy,
Can the Enya 60 be retrofitted into an existing plan built around the PA 61?
James
AMA 491167
Re: Enya 60 question for Randy
« Reply #1 on: December 03, 2010, 09:10:38 PM »
Randy,
James
I am sure it can be, BUT  if you mean a drop in fit  NO.  it will take some work
Offline Martin Quartim
    • StuntHobby
« Reply #2 on: December 04, 2010, 06:44:49 AM »
A friend said he swapped a PA-61 with an Enya 61CXLR RE and the mounting holes and overall dimensions matched.
This chart has all the Enya engines Dimension
http://www.enya-engine.com/DimensionCL_E.html
Martin
« Reply #3 on: December 04, 2010, 04:41:05 PM »
Thanks for that link, Martin. I giggled  y1 over the column header "Plopeller size".  LL~  Steve
    • StuntHobby
« Reply #4 on: December 04, 2010, 09:14:12 PM »
welll enjoy the Sport and "Stant" proppeller
http://www.os-engines.co.jp/english/line_up/propelle/proindex.htm
The "Zylinder"  made from aluminium
http://www.webra-austria.at/motor.php?folder=TECHNICS&lang=EN
 n~
Martin
Offline Chris Wilson
« Reply #5 on: December 05, 2010, 05:36:05 PM »
I am almost 100% certain that 'Stant' was a brand of prop back in the 60's though!
MAAA AUS 73427
« Reply #6 on: December 05, 2010, 08:24:36 PM »
 n~
Martin
Oh, MY! We're having a great time yukking it up now!  LL~ Steve
Offline Steve Fitton
« Reply #7 on: December 06, 2010, 09:52:04 AM »
A guy in our club has an SV-11 ARF that I believe is set up for either an Enya 61 RE or a PA.  The only issue might be if the length of the pipe tunnel will accomodate Enya pipe lengths.
