  • July 07, 2025, 05:28:35 PM
Author Topic: Blank  (Read 2821 times)
Blank
« on: December 09, 2017, 10:03:09 AM »
Blank
« Last Edit: December 07, 2021, 06:33:51 PM by Motorman »
Offline pmackenzie
  • Pat MacKenzie
Re: Fox 36X Bore Size
« Reply #1 on: December 09, 2017, 10:18:59 AM »
MAAC 8177
Offline Al Ferraro
« Reply #2 on: December 10, 2017, 06:37:44 AM »
Same as the 35 Stunt engine.
Al
« Reply #3 on: December 10, 2017, 04:11:01 PM »
The Peter Chinn article is great.  He really studied the engines.
Fox made a logical business decision to stay with his standard .800 x .700 bore & stroke, which (no doubt) fit his tools.
He then realized that he could stroke the engine to .715" and use ALL of the .36 cubic inches under the rule.   Around my area, guys were scrambling to get the all-important "stroker" cranks.  I never heard even ONE guy mention the need to deal with the resultant .0075" loss of head clearance.
But a 36X setup inside a Fox 35 Stunt case would be illegal under current rules that forbid increasing the displacement.
The whole thing was a moot point vis a vis the C35 and G21/35.
« Reply #4 on: December 10, 2017, 04:12:43 PM »
Going from .352 to .360 was only about a 2% potential improvement, which was chump change compared to a "C".
« Reply #5 on: December 11, 2017, 09:02:36 AM »
If the bore size is the same as a Fox 35 and you use the fox 35 crank then it's still a 35.
Correctomundo, sir.
You just can't use the .715" stroker.
« Reply #6 on: December 11, 2017, 04:35:04 PM »
I wondered that about in Profile Carrier in the olden days at The Nats.  The answer was: Only if the losers complain or if it sets an AMA record.
The rules of Fox 35 Stunt speed are such a bowl of jelly, there's nothing much to inspect.
A few years ago, I was able to win Fox 35 Stunt Racing at Muncie and I was subjected to a tear-down, which I passed. But that was under the stock engine rule.
« Reply #7 on: December 11, 2017, 07:49:18 PM »
I did not  realize  that a  FOX  36  crank would  even fit in a  FOX 35 Stunt
Offline Al Ferraro
« Reply #8 on: December 13, 2017, 10:05:13 PM »
[/quote]
 The Fox 36 crank is to long. There are a couple of 35 Stunt engines that guys have installed a Fox 35 Black head 1/2 inch crank. It also has a larger crank pin than the Stunt engine, which could be ground off center to get more stroke if someone want to make a cheater crank. One guy was using a custom 12mm crank in his Fox 35 Stunt engine.
 The High Zoot crank that I bought from you retimed is the King of the hill in Fox Speed.
Al
