  • July 15, 2025, 11:01:12 AM
Author Topic: Enya 5224 & 5225.  (Read 1197 times)
Offline Robin_Holden
Enya 5224 & 5225.
« on: May 31, 2021, 01:26:27 PM »
Good day guys from Spofforth in North Yorkshire , England.
I have two Enya 35’s.
A 5224 and a 5225.
The 5224 has the square plastic Venturi insets.
Apart from that I don’t detect any real differences
Are there any real differences between these two 35’s ?
They both appear to perform the same.
Thanks for any help in this matter,
Robin.
Offline GERALD WIMMER
    • Auckland Free Flight Club
Re: Enya 5224 & 5225.
« Reply #1 on: May 31, 2021, 09:44:50 PM »
Hello Robin
This post has a lot of info at the Barton Club site:
http://controlline.org.uk/phpBB2/viewtopic.php?t=9044
Enya made so many versions of its 29' 35 engines with differences even with the same model number.
Regards Gerald
Offline pat king
    • PDK LLC
« Reply #2 on: June 01, 2021, 09:48:33 AM »
Robin,
With the 3 different venturi sizes, the two heads and the timed crankcase pressure availability your 5224 engine is very adaptable. The "B" model 5224 engines with the round Aluminum venturi Inserts do not have accommodation for timed crankcase pressure.
The 5225 engine has 3 venturi inserts available, high compression is obtained by removing the head shim that comes from the factory. There is no provision for crankcase pressure. There is a boss in the back of the crankcase that can be drilled and tapped for a low pressure crankcase pressure tap. The 5225 does carry a steel thrust washer hidden in the nose of the front housing that makes it much more accepting of starters.
Pat
Pat King
Monee, IL
AMA 168941
