  • June 20, 2025, 10:33:14 AM
Author Topic: Enya 49X  (Read 5237 times)
Offline dennis lipsett
Enya 49X
« on: November 30, 2010, 11:05:24 AM »
To continue on with another thread about engines that have disappeared from the modelling scene I have the following. A brand new and a used Enya 49X. These were made perhaps early 80's and I used one for R/C with the usual Enya results. it was outstanding. However, most of the X and CS series probably wern't used for C/L because of weight.
So I'm going to ask if anyone ever used the 19X, 49X, 40/46/50 CX in any capacity in C/L
 as I'm not flying R/C anymore it is a shame to have this large stash of engine sitting unused. It defeats the purpose that they were made for.
Dennis
Offline Martin Quartim
    • StuntHobby
Re: Enya 49X
« Reply #1 on: November 30, 2010, 09:00:10 PM »
Hi Dennis,
The 49X is very similar to the actual Enya SS50, same bore and stroke. I just not sure about the timing, but it is probably the same.
The Enya 49X with venturi is lighter then a ST G51, so weight is good for C/L. As matter of fact there are many Enya engines that are very light, if not the lightest in it's class. Some how people got stuck with this idea that Enya engines are heavy, when it is the other way around....try to beat the weight of a Enya 40XZ , 61CX or SS50. I also just got an Enya 45CXL Rear Exhaust and it weighs a lot less then a OS 46VF.
This engine will work best with low pitch props, 12x4 to 13x4. A friend is using an Enya SS50 with 8.0mm venturi, stock muffler, 3 blade 12.5x3.75 carbon prop on a 65Oz a .60 size model. Launch it 9800rpm, laps 5.2s and it does a 4-2-4.
This is a video made last year when we started using the Enya SS50. Its all stock and we used an air filter to restrict the venturi. The tank height was not right,  it got much better run symmetry once the tank height was adjusted.
And here is a video of an Enya 61CX
Martin
Re: Enya 49X
« Reply #2 on: December 01, 2010, 08:51:07 PM »
I'm pretty sure one was used by Bill Simons on his Rogue at the Nats. What, early 80s some time?
« Last Edit: December 02, 2010, 10:04:13 AM by Randy Powell »
Re: Enya 49X
« Reply #3 on: December 02, 2010, 01:55:33 AM »
The notorious Englishman with the super Hawk used 40 CX s ,.29 ? Venturie .
Filed early lighter muffler to fit , or filed engine .
Engine Test timing figures show 49 to be conservativer than 40/45 on sleeve
so theoritically tourqueier .
He filed lug hole slotted to interchange with earlier motor, Info was in
Aviation Modellor international, 1980s . May be info on CLAPA or Dave Day sites.
Re: Enya 49X
« Reply #4 on: December 03, 2010, 06:51:45 AM »
Mufflers are the real problem with this engine. It has a narrow spacing of 1-3/16 between centers for the bolts. I've checked every tongue muffler that I have and that is a considerable lot and I don't have a match. The stock muffler is too large and heavy and of course ugly to use. Guess it will need an adaptor plate .
Offline Allan Perret
  • Proverbs
Re: Enya 49X
« Reply #5 on: December 03, 2010, 08:26:09 AM »
Martin
45CXL,  what is that, an older model RC engine ?
Allan Perret
AMA 302406
Slidell, Louisiana
    • StuntHobby
Re: Enya 49X
« Reply #6 on: December 03, 2010, 09:11:46 AM »
Hi Dennis,
Macs Products has a header for  49X.  http://www.macspro.com/headers_side.asp
Look for Headers .35-.555 PN  2420, 2421,   2422 and 2423
You can mount the engine at .45 like Igor Burger has done and use a pipe with it.
Or you can make a header muffler. I made a header muffler for an Enya 61CX RE attaching a deflector with JB Weld. The JB weld does not stick to the deflector but it will hold the deflector in place and do a pretty good job sealing the gases. It has been working for a while now.
Martin
Re: Enya 49X
« Reply #7 on: December 04, 2010, 10:15:51 AM »
Hi Dennis,
Martin
Martin. Thanks for the ideas but it is easier to mill an adaptor plate for a current tongue or Big Art muffler. I don't run pipes yet since I only used them before for a performance boost. However, I'm getting ready to try one soon. I assume that the 45 RE is a new offering from Enya.
dennis
    • StuntHobby
Re: Enya 49X
« Reply #8 on: December 04, 2010, 10:54:09 AM »
Hi Dennis,
No the 45CXL is not been offer by Enya, it is old and I got it from Ebay.
Martin
Re: Enya 49X
« Reply #9 on: December 05, 2010, 08:42:45 PM »
  Bobby would know, but my rapidly-fading memory tells me this one of of the many "schneurle wars"/"greatest engine ever this month" engines from that time frame. But other than that I don't know anything about it.
Re: Enya 49X
« Reply #10 on: December 05, 2010, 09:21:06 PM »
Hi Dennis,
Martin
Martin,
I have a 45CX but it was referred in another thread as a R/E engine and that was something that I didn't know existed. So I figured that it might be a new offering.
Dennis
    • StuntHobby
Re: Enya 49X
« Reply #11 on: December 06, 2010, 09:19:02 AM »
Hi Dennis,
From what I understand  just a very few of the 45CXL R.E  landed in the US market back then. It has a price tag of U$179,99  probably a lot more expensive then the OS 40/46VF at the time.
Martin
Re: Enya 49X
« Reply #12 on: December 06, 2010, 09:39:49 AM »
Brett,
I'm not certain, but I read the Flying Models article and I seem to remember that's what it was.
Offline Mike Ferguson
Re: Enya 49X
« Reply #13 on: December 06, 2010, 01:59:08 PM »
The Flying Models article mentions the Enya 49 being used in 1981.
And a switchover to the ST 60 in 1982 ... along with 10 ounce tanks and 15 inch props.  :)
Which fits in with my memories as a kid - pretty much all the New Jersey-based flyers switched over from the various schneurles and the ST 46 to the ST 60 in 1982-1983.
    • StuntHobby
Re: Enya 49X
« Reply #14 on: December 06, 2010, 10:06:24 PM »
This switch back to older technology does not make any sense, at least not with what we know now.
What I have observed is that Cross flow engines running 5 to 6 pitch prop are gutless compared to schenuerle engines using 3.75 to 4.5 pitch props. In a normal day it probably doesn’t matter much, but in a windy day it is clear the disadvantage of cross flow engines like the ST 60.
Martin
