  • July 12, 2025, 06:14:23 PM
Author Topic: Enya .45 6002  (Read 6346 times)
Offline richardhfcl
  • AMA 82448
Enya .45 6002
« on: April 04, 2015, 12:54:46 PM »
Gentlemen,
     For years out at our field the Enya .45 6001 has been a good, dependable stunt performer.  Today,
one of our newer flyers indicated that he has an Enya .45 6002, and did I know anything on how to set
it up?  I don't know the 6002, unfortunately.
     Are the two engines very different in running characteristics?  Is a different set up used for the 6002
than the 6001?
     Thank you!
Richard Ferrell
AMA 82448
Offline Martin Quartim
    • StuntHobby
Re: Enya .45 6002
« Reply #1 on: April 04, 2015, 10:00:11 PM »
I have experimented several Enya engines with great results and I am sure the 45 6002 will work amazingly well too. I hope some one will post their experience with one.
I have no practical experience with the 45 6002.  It seems to me that the 4002 has larger internal fuel passage and maybe the port timings are a bit different, but still should be a very good for C/L. The 6002  head is interchangeable with the 6001, it has a  higher compression and as matter of fact I like to use the 6002 head with my 45 6001 engine.
If you tell me what plane your friend plans to use I can give you a starting point.
For a Pathfinder/Oriental Plus/RSM P=40k/DQ Master size model I suggest this venturi
https://cs206.xbit.jp/~w041133/store13/index.php?main_page=product_info&products_id=379
This NVA
https://cs206.xbit.jp/~w041133/store13/index.php?main_page=product_info&cPath=3_18&products_id=373
12x6 or 12x5 prop and 62' Lines
For a smaller plane you can use a smaller venturi like this one:
https://cs206.xbit.jp/~w041133/store13/index.php?main_page=product_info&cPath=3_19&products_id=378
with props like  11x6 11x5 or even a 10x6
good luck,
Martin
« Last Edit: April 09, 2015, 01:13:31 PM by Martin Quartim »
Offline Andrew Tinsley
Re: Enya .45 6002
« Reply #2 on: April 06, 2015, 08:23:53 AM »
I have followed the same ground. One very well respected Australian stunt flyer had his 6002 crank shaft internal bore sleeved down to the same diameter as the that in the 6001 and this made all the difference. I have tried it and can confirm that the engine is much improved. I cannot tell a great deal of difference between the two engines after the modification.
Another tip is to use an ST46 head. This makes the engine have that ST growl and probably performs like one too if I were a better pilot,  could perhaps tell!
Andrew.
BMFA Number 64862
Offline Chris Wilson
MAAA AUS 73427
Offline Ara Dedekian
  • Ara Dedekian
Re: Enya .45 6002
« Reply #4 on: April 07, 2015, 06:55:30 AM »
     Go to page 3 of this topic to, 'Enya 45s' for a good discussion and lots of info on the 6001 and 6002.
Offline Allan Perret
  • Proverbs
Re: Enya .45 6002
« Reply #5 on: April 12, 2015, 12:07:19 PM »
Andrew.
Sleeving the crank bore,  can you explain how that is done, and what material is used for that.
Also, what does that do that a smaller venturi would not also do ?
Do you know if the 6001 crank will work in the 6002 ?
« Last Edit: April 12, 2015, 12:38:11 PM by Allan Perret »
Allan Perret
AMA 302406
Slidell, Louisiana
Re: Enya .45 6002
« Reply #6 on: April 12, 2015, 07:30:10 PM »
Aluminium tubing that is Lockite glued in.
It keeps the lower crankcase volume small and more importantly the gas speed high.
No idea.
MAAA AUS 73427
Online Brian Hampton
Re: Enya .45 6002
« Reply #7 on: April 14, 2015, 10:41:17 PM »
The short answer is NO :).
The long answer is that there are too many differences which makes a straight swap impossible. For starters, the PCD of the retaining screws for the front housing is quite different. The 8 ball rear bearing of the 6001 fits the 12.7mm crankshaft with its 9.5mm bore while the 6002 uses a 10 ball bearing for the 15mm crankshaft and 11.4mm bore. The bore in the crankcase is different too. The 6001 is 28.5mm to suit the outer race which provides alignment while the 6002 is 29.9mm and uses a machined extension of the front housing to enclose the rear bearing and provide alignment. Apart from a minor difference in stroke (.2mm IIRC) the 6001 has a 6.3mm crankpin while the 6002 is 6mm so you'd need to swap rods. There are other minor differences such as the crankweb on the 6002 being 1.1mm larger than the 6001.
« Last Edit: April 15, 2015, 06:44:57 PM by Brian Hampton »
Offline Balsa Butcher
  • High Desert Flier
Re: Enya .45 6002
« Reply #8 on: April 15, 2015, 12:22:30 AM »
Easier to just check Da-Bay until a 6001 shows up. They usually go for cheap, especially compared to ST-46's. R/C same timing as C/L version. Parts available, bearings available, rings available from Frank Bowman. Good, often under appreciated stunt engine.  8)
Pete Cunha
Sacramento CA.
AMA 57499
