  • July 24, 2025, 02:28:01 AM
Author Topic: Enya 45 6001 prop shaft extension?  (Read 2231 times)
ChrisSarnowski
« on: April 17, 2012, 06:27:52 PM »
Hi Guys,
I have an Enya 45 6001 that I would like to use in an airplane, but it needs a prop shaft extension.
The Enya 45 has a 7x1mm threaded shaft. All the Fox adapters are english units.
Anyone make a 7x1mm extension?
Chris
ps. Extension length is 1/2" or thereabouts metric.
Offline Bill Hummel
Re: Enya 45 6001 prop shaft extension?
« Reply #1 on: April 18, 2012, 04:27:58 AM »
Hi, Chris, if no good ideas pop up here, I'd suggest contacting Jim Lee at Lee Machine Shop. He has made various bits and pieces for stunt engines over the years. I believe he can help you with this problem!  Might also call Randy Smith to see what he has or can get for you.  Happy hunting!
ama 72090
Offline Richard Field
« Reply #2 on: November 21, 2014, 11:11:43 PM »
Hi Chris,
Did you manage to source a suitable 1/2" prop shaft extension for the Enya 45 6001?
I recently picked up a set of Stiletto 660 Foam Wings & see the plan calls out for a 1/2" extension. Will likely be fitting an Enya so am now looking for the same item...
Richard
Offline bob whitney
« Reply #3 on: November 25, 2014, 09:55:03 AM »
 if i have the engine ,i can make a spinner backplate with the 1/2 in ex  to fit the spinner then make the prop nut and adapter to fit everything together ..i use a S/T type collet to mate to the shaft
rad racer
« Reply #4 on: November 26, 2014, 09:50:57 PM »
How many pennies are these there extended prop drives .
Need on for a .46 ST , so'd replace prop driver & increase stock length 3/4 or 1 inch , to Brodack 1 3/4 spinner .
unless we go a little more technical , with a 1 7/8 prop cover washer with uncut 1 3/4 forward , for now .
as a freewheel contra prop in front'd need a few more bits . and WEIGH MORE , which is likely unacceptable .
1 " would get the motor further back , so is preferable, thanks .
« Reply #5 on: December 05, 2014, 01:48:45 AM »
Thanks very much Bob, will keep this in mind. The Stiletto build is still some time away yet - the Foam Wing Set was an impulse purchase #^ as it's not exactly a frequent find downunder...
Cheers,
Richard
« Reply #6 on: February 10, 2015, 08:14:32 PM »
A check of the Brodak catalogue revealed a 1/2" extension for 7mm Shafts intended for the larger Saito Engines..with 1/4-28 threads ready for a spinner retaining bolt. P/N BH-987 refers. Now on order with my local dealer :). Too easy.
