  • July 17, 2025, 05:21:58 PM
Author Topic: Enya 45-11 # 6002  (Read 1866 times)
Offline Paul Allen
Enya 45-11 # 6002
« on: August 12, 2012, 03:41:35 PM »
Hi guy's
            Anyone  using this engine? Current model on Enya website.
Thanks.
Offline Chris Wilson
Re: Enya 45-11 # 6002
« Reply #1 on: August 12, 2012, 04:40:52 PM »
Hi guy's
Thanks.
Hi Paul,
            a couple of fliers at the Doonside club here in OZ have used them (Les Spaltman still does I think and Herb H used to) and they seem to be good engines but they suffer from the competition being that much better. In the same genreŽ a Tigre 46 is probably a better engine.
But its a good question mate and since they are still available for sale and the Tigres aren't ...........
MAAA AUS 73427
Offline Steve Thomas
« Reply #2 on: August 12, 2012, 05:16:05 PM »
The 45-I (6001) is generally regarded as a better stunt engine, and as good as an ST46.  They're reasonably easy to get hold of.  I believe the 45-II has different timing - not quite as stunt-friendly.
« Reply #3 on: August 12, 2012, 05:51:47 PM »
MAAA AUS 73427
Offline Brian Hampton
« Reply #4 on: August 12, 2012, 11:02:42 PM »
I used the 6001 for many years back in the 60's-70's with great success and was sometimes asked by other flyers (like Peter White) how I got it to run like an ST46. All I could say was that it was bog standard and all I did was fill the tank and go fly :). Later I bought a 6002 when they first came out with the thought that newer should be better. Unfortunately it wasn't as good for stunt, not that there was anything bad about it, but the run was quite different being timed more for RC so it went into a drawer where it remains today.
Offline Paul Allen
« Reply #5 on: August 14, 2012, 04:03:08 PM »
Brian
      Can you remember what fuel and prop you ran on the #6001.
Offline Balsa Butcher
  • High Desert Flier
« Reply #6 on: August 14, 2012, 04:57:04 PM »
I run mine on GMA 10% 11/11 with a RSM 11x6 prop. Runs like a ST-46. Since it is a ringed/bb engine it has not needed the long break in times that my iron pistion Enyas seem to like. 8)
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #7 on: August 14, 2012, 06:25:34 PM »
I'm running an MA 10x7 3-blade (due to ground clearance issues), and 5/11/11 fuel. It gives a great run every time.
« Reply #8 on: August 14, 2012, 11:25:39 PM »
Brian
It's a loooooong time ago now but I remember the fuel I used was just 75/25 all castor and I think the prop was a wide blade 11x6, probably a Top Flite or whatever was locally available at the time. Nothing fancy at all. After a couple of hundred hours it was no longer giving one flick starts (although once running it was still as good as ever) so I fitted new rings to cure it. Mine being the first version it had twin rings, the later version (from about '73) had a single ring like the new 60-IIIB.
Offline Paul Allen
« Reply #9 on: August 14, 2012, 11:49:32 PM »
Thanks guy's
