Engine basics => Engine set up tips => Topic started by: Paul Allen on February 17, 2010, 02:06:50 AM
Title: Enya 40 XZS
Post by: Paul Allen on February 17, 2010, 02:06:50 AM
Well I have been using this motor in an Oriental full fuz model.
Has about 20 flights on it after running in on test bench,it runs
nice but has one problem,it bogs down rich after the recovery
to normal upright flight from the three outside loops,same again
in the last inside loop of the clover,its like fuel is pooling up in the motor
then tries to drown the plug the rest of the pattern is fine,Sig R/C glow
plug with idle bar,fuel is 11.5 % klotz,11.5% castor,3% nitro& remainder
methanol,11 x 5 Brodak smooth finish prop,have tried a number of hot plugs
same result release RPM about 9,100,uses 90cc of fuel for 6min 30 sec flight.
Still able to complete the pattern just a little worried about it stopping in the
climb out from the clover.
Randy any suggestions?
Title: Re: Enya 40 XZS
Post by: Balsa Butcher on February 17, 2010, 11:51:26 AM
My suggestion would be to try another prop. The Brodak prop is a wide blade design and some newer engines work better with a narrower style. APC 10 1/2x4 1/2, 11x4,11x5, the similar sized Thunder Tiger props, or any of the high-zoot CF props (available from Randy Smith) would be worth a try. The engine might be happier at a higher RPM. This doesn't mean that it has to run in a 2 cycle, many modern engines (like the Brodak 40) will hold a high RPM 4 cycle run. Hopefully this is one of them since I have one but have not run it as of yet.  8)
Post by: RandySmith on February 17, 2010, 04:00:11 PM
Hi Paul
What muffler setup are you running, and are you using pressure?
What type tank are you using and is it metal plastic uniflow etc?
Sounds like it could be not quiet broken in yet too, Tight motors will do that when coming out of a leaner setting when they need a little more break in time. To test that try holding the plane on the ground with a solid 4 cycle setting, turn the nose up and let it go into a 2 cycle for about 10 to 15 seconds then quickly put the nose back level, see if the motor stumbles. If so more time and a lower pitch prop with less load will help.
Also  I would use either a  T Bolt RC long , Glow devil 300 Long, Enya 3#  , T Bolt Big Bore  as very good plugs for that engine
let us know how it goes
Regards
Post by: Paul Allen on February 17, 2010, 08:38:20 PM
        Muffler, is your tongue type as used on Aerotiger,uniflow
metal tank with uniflow pipe open to airstream.
Plugs have tried a couple of the ones you suggested before
same result ( Enya 3,  T Bolt R/C Long ).
Will try your test on model and see what happens,I was not sure
if the new Enya's would need as much running as the old type.
Paul Allen
PS I removed the tube muffler as I felt it was too restrictive,
runs better with the tongue.
Post by: Martin Quartim on March 06, 2010, 08:06:56 PM
Paul,
I have no experience with this engine, but I know these Enya Engines are r/c converts to c/l and seems to me that Enya timing targets best torque above 10500rpms. May be Randy can clarify the best RPM range to work with this engine.
With my SS30 and SS50 I didn't get spectacular performance with a 5 to 6 pitch props but when using 3.75 to 4.5 pitch..then it was Wow!
Based on my experience with other Enya engines, I guesstimate that a 7.5mm venturi and a 11.75x4 prop should pretty close to the sweet spot. Also I'd try one and two head shims to see how it would go.
The stock muffler on the SS30 which is the same as on the 40XZ worked pretty well and it is pretty light. Later I bore out the exhaust exit and smooth out the inside of the muffler. I didn't measure any performance improvement but I guess it made a difference, if anything it is running as good as before with less weight.
This is just my personal opinion for you to think about it and see if it is worth trying.
Martin
Post by: Paul Allen on March 09, 2010, 04:16:58 PM
Martin
         Re the prop, I tried a 10.5 x 4.5 APC still had the same result.
The Brodak smooth 11 x 5 pitch's to 4.8 at station 10 on the gauge.
It pulls the plane well it just seems to be a bit hit and miss.
If set at 9,000 rpm it runs in a fast 4 cycle and will bog down as described
If it goes to to 9,200 rpm, it is in a wet 2 cycle and is better.
First run of the day is the worst.
Have switch to a Glow Devil # 300 plug which seems better.
Tried an OS 4 stroke plug, motor was to aggressive, motor was not happy!
I would think that it should be run in by now, about 4 hours on it ?
Post by: Martin Quartim on March 09, 2010, 07:30:02 PM
Hi Paul,
It seems the engine is telling us it needs to work in higher rpms to make the air/fuel mix flow faster inside the crank.
I believe a 40 size engine to be to small to work in 4-4-4 with an Oriental. I'd go for a 2-2-2 type run with it.
The APC 10.5x4.5 works well with in my Enya SS30, I'd expect the 40XZ to need the load of a 11.25x4 prop, at least.
In your shoes, I'd try to get the Engine set up (venturi size and head shims) to launch around 105000 rpms. I would start with an APC  11.5x4 prop or a CF prop 11.5~11.75 letting the light wood props for trying last.
Martin
Post by: Steve Helmick on March 09, 2010, 08:39:55 PM
"I believe a 40 size engine to be too small to work in 4-4-4 with an Oriental. I'd go for a 2-2-2 type run with it."
It seems that Martin is thinking of the Oriental Plus...same designer, different plane. The Classic "Oriental" flies fine with .32/.36 engines, Brodak .40, etc.  I'm sure the Enya will do just fine, with the right setup. A "search" might turn up some data from folks what's used them.  H^^ Steve
Post by: Martin Quartim on March 10, 2010, 09:57:54 AM
Hi Seteve,
I am very familiar with both Oriental. The Enya 40XZ should be strong enough even for the Oriental Plus. What I meant is that running the 40 in the 4-4-4 mode it may not run strong enough. I could be wrong, but I believe this engine will develop a lot more torque in 2-2-2
Martin
Post by: Michael Massey on March 10, 2010, 10:29:41 PM
I have the same engine and found that it took a LOT of breaking in time.  When I finally "creamed" the airplane the Enya was on, I had about 5 or more hours of flight time on the engine and it was running great.  No 4-2-4 but a consistent, reliable run.  It probably took 2-3 hours to get the engine to "settle down" to predicable.  I was running a pretty standard Zinger 11-5 and 10% nitro with about 15% Caster and 5% Synthetic, only because that is what I had.
I fly in Oregon so the weather was colder and more humid.  I like the Enya and am about ready to start a replacement plane.  When I do, I will probably change to 10% Nitro, 10% Castor and 10% Synthetic only because I need to somewhat standardize on just a few different fuel mixtures.
