Engine basics => Engine set up tips => Topic started by: Harry Rice on September 23, 2006, 08:41:27 AM
Title: Enya 35V's - Any use?
Post by: Harry Rice on September 23, 2006, 08:41:27 AM
Hi Folks,
I have been given by one of our business customers two Enya 35V's. They both are pretty new (well, certainly not used much!) - start on bench easily (without nitro), and seem generally in fine condition.
The questions are:
1. As they are both r/c versions can they be converted to c/l at reasonable cost?
2. Are they any good as c/l even if (1) is true?
I do not have any project immediately at hand for them but thought they might be worth hanging onto "just in case".
Any info gratefully received.
btw - UK based but bits from USA not a problem.
Cheers
Harry
Title: Re: Enya 35V's - Any use?
Post by: Leester on September 23, 2006, 09:11:49 AM
Harry: Not sure of your costs in the UK but you should be able to convert at a modest price. I'd keep them and try them in a plane, of course I don't throw anything away. Never know they may be outstanding runners.
Post by: Bill Little on September 23, 2006, 05:46:37 PM
The Enya 35V should be just fine for C/L use.  If broken in correctly and kept clean, I don't believe you can ever wear one out!  They are pretty strong 35 size engines.
I would suggest a "wet 2" run, as their timing is just a tiny bit high for a good 4-2 run.  An APC 10 1/2-4 1/2 prop should work pretty good as a starting point.
Venturi and NVA might still be available from Enya or one of their distributors.  I remember someone lately geting some new ones for their engine.
Bill <><
Post by: Tom Dugan on September 23, 2006, 06:58:29 PM
You can try Enya for for a venturi, if they are no help contact Scott Riese (member this forum)  He made a venturi for an Enya 60 that I have.  I have a line of Enyas 15 thru 60, all are great engines.
Thomas
Post by: Bill Little on September 23, 2006, 08:15:00 PM
Thomas
Hi Tom,
I had an Enya 60 in a Super Chief years ago.  Lord, it was a big ol' heavy engine, but it ran like a fine Swiss watch!
Scott Riese is a super guy to deal with.  y1
Bill <><
Post by: Annette Elmore on September 24, 2006, 01:46:13 AM
Steve Webb is the importer for Enya in the UK and seem to have endless supplies of spares - are they square or round intake?
http://www.stevewebb.co.uk/
Tony
Post by: Harry Rice on September 24, 2006, 08:24:48 AM
Many thanks for the informative replies - looks like I'll be keeping them then!
(Tony; Will contact them tomorrow re nva. The current throttle bodies are sort of squarish barrel shaped affairs.... If you email me your address I will post you an aerosol  can of solvent cleaner we use at work. Should be ideal to flush out small bearings of debris - it's residue free. I assume you can do this via this site? I also assume you are in the Uk (Flag a bit of a clue!!))
Cheers
Harry
Post by: Harry Rice on September 25, 2006, 09:21:30 AM
Hi People,
Thanks for the help - have ordered c/l venturi and nva from Steve Webb - 10GBP. Cheap enuff...
Next problem will be something to put it in!!
Cheers
Harry
Post by: Tom Dugan on September 25, 2006, 11:46:35 AM
Good Luck Harry!
Keep us posted on what you build and how it flys with that Enya.
Thomas
