Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
---->Stunt News click here<----
July 10, 2025, 08:30:07 PM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
Enya .35 Venturi
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Enya .35 Venturi (Read 3411 times)
Adam Riehl
Trade Count:
0
New Pilot
Enya .35 Venturi
on:
December 13, 2019, 06:51:46 PM »
I have an Enya .35 5224 engine with a RC carb on it. I would like to convert it to CL, but don't know where to get parts. I know I need a venturi and NV/Spraybar. Can I use the current NV? Is there an O.S. venturi I can use? Also, it is a round intake model.
Logged
Bill Adair
21 supporter
Trade Count:
0
Captain
AMA 182626
Re: Enya .35 Venturi
Reply #1 on:
December 13, 2019, 08:25:38 PM »
Adam,
Welcome to the forum!
Shtterman, a seller on eBay has a large selection of Enya parts and engines. He should be able to fix you up with the parts you need. Very nice fellow to deal with, and I've never been disappointed with his service.
Logged
kenneth cook
Trade Count:
0
Admiral
Reply #2 on:
December 14, 2019, 06:37:50 AM »
Bob Brooks 954-234-0863
Logged
Adam Riehl
Trade Count:
0
New Pilot
Reply #3 on:
December 14, 2019, 09:14:38 AM »
Would this work? Mine has the round intake. I'm not sure about most of this stuff. It is quite different from the O.S. engines I have always ran.
https://www.ebay.com/itm/ENYA-29-35-MODEL-5224-ROUND-C-L-VENTURI-NEEDLE-VALVE-ASSY-NIP/293043955619?hash=item443ac7e7a3:g:qvoAAOSwaZdZvGeW
Logged
25 supporter
Trade Count:
0
Admiral
Reply #4 on:
December 14, 2019, 10:05:29 AM »
Hi Adam;
If you have paper work with your engine, see if it has part numbers for the venturi and such. If not, shtterman should be able to tell you. I think he lists his phone number in his auction listings or might be in a post on the forum here somewhere. One thing to remember is that the Enya NVA and the OS NVA are different. Needles from one won't work in the other. When you get it set up, the Enya will need a lot of break in time. They have very good metallurgy in them and fit pretty tight. I think shtterman is connected to the Enya factory pretty closely because he had them make NVA sets to OS specs for him. Good luck and have fun!
Edit to add:
https://stunthanger.com/smf/open-forum/looking-on-ebay/
His eBay store and contact number are in this thread.
Last Edit: December 14, 2019, 02:30:19 PM by Dan McEntee
Logged
EAA 1038824
pat king
24 supporter
Trade Count:
0
Admiral
Reply #5 on:
December 14, 2019, 02:39:49 PM »
Do not get a #3 venturi. For Stunt the #1 gives plenty of power and has the best suction fuel draw. You need a 29420 Needle Valve Assembly, a 29421B venturi, and a 29424B venturi gasket.
Pat
Logged
Pat King
Monee, IL
AMA 168941
M Spencer
Trade Count:
0
Admiral
Reply #6 on:
December 14, 2019, 06:39:17 PM »
Yep. was just gonna say , these engines came with THREE VENTUIES & two cylinder heads . High & low compression ' wedge ' .
The smallest venturies still generous . .280 odd . And fits a cross drilled S Tigre .46 . Thus a ' spare ' aftermarket 21/46 stunt venturie cross drilled
should drop in . If you see one floating past .
Logged
YakNine
AMA Member
Trade Count:
0
Commander
Reply #7 on:
December 25, 2019, 07:39:01 AM »
Jim Lee makes a round Venturi that is for converting the R/C models. TJ
Logged
AMA 85135 GSCB
katana
Trade Count:
0
Commander
Reply #8 on:
December 25, 2019, 10:47:38 AM »
IF you have a lathe, it takes little more than 10 - 15 minutes to make a venturi AND you can bore them to multiple sizes to give options. I seal mine to the c.case with a thin 10mm o ring. all held and compressed with an Enya spray bar and needle assy.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Enya
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
Enya .35 Venturi
