  • July 25, 2025, 08:07:24 PM
Author Topic: Enya 35-III limited run several years ago  (Read 888 times)
Offline DanielGelinas
« on: June 19, 2012, 07:53:35 PM »
Hi Guys,
Just purchased an Enya 35-III with three venturi's NO MUFFLER.
This is an ENYA from there limited run several years ago.
The engine has only one head.
Does anyone know (in this limited run) if the head is High or low compression?
Thanks! H^^ H^^
-Daniel
Offline Brian Hampton
Re: Enya 35-III limited run several years ago
« Reply #1 on: June 20, 2012, 02:05:27 AM »
It sounds like the head is from the later Enya 35-V where they did away with the second head and used a shim to adjust compression. In that case it'll be fitted with a shim making it the low compression. IIRC the earlier engines came with the low compression head fitted.
« Reply #2 on: June 20, 2012, 08:09:01 AM »
THanks Brian H^^
