  • June 21, 2025, 12:14:09 PM
Author Topic: Enya .29 5224 prop size  (Read 2499 times)
Offline Ron Cribbs
« on: July 15, 2015, 09:03:05 PM »
Hey guys,
I have an old Bi-slob that was given to me that has an Enya .29 on the nose.
I have stared at it long enough now and I am going to fly this thing. I ran it with an MA 10x6, but was wondering if that is the best choice. Seems a little down on power to have this thing hanging on the prop.
Ron
Re: Enya .29 5224 prop size
« Reply #1 on: July 16, 2015, 07:49:57 PM »
Hi Ron,
I have some 9 1/2 X 6 petal blade George Aldrich props that I use on my .29s.  So far they have been a pretty good choice for all of my .29s.  I would try trimming the 10 X ^ to a 9 3/4" first and then 9 1/2".  The MAS props are pretty cheap and you will get a good look at how prop diameter affects the model.
BIG Bear
RNMM/AMM
Offline Ron Cribbs
« Reply #2 on: July 18, 2015, 10:16:51 PM »
Thanks Bill, I appreciate the info!
Online Tim Wescott
« Reply #3 on: July 18, 2015, 11:35:28 PM »
Or try a 10x5, and needle it to run a bit faster.  Bi Slobs need such an odd engine run I'm not sure if it'll do but -- try it.
Offline Balsa Butcher
  • High Desert Flier
« Reply #4 on: July 19, 2015, 04:32:54 PM »
I used to run one in an All American Sr. for OTS. 9X6 Topflite worked well. Needed the short prop smaller diameter prop because of ground clearance issues.  8)
Pete Cunha
Sacramento CA.
AMA 57499
