  • July 08, 2025, 10:08:38 AM
Author Topic: Enya .29  (Read 1156 times)
Offline bob werle
Enya .29
« on: July 27, 2010, 10:15:20 PM »
I found an old Enys .29 that neets some tlc.  This particular wngine has a black plstic venturi insert.  Would it be safe to crockpot this with the insert in place?  All my other Enya's have metal inserts.  This is a square plastic insert.
ama 5871
Offline Leester
Re: Enya .29
« Reply #1 on: July 28, 2010, 06:47:50 AM »
Arn't the inserts removable  ??? Don't know if the crock pot gets hot enough to hurt them or what the anti-freeze would do.
Leester
ama 830538
Re: Enya .29
« Reply #2 on: July 28, 2010, 09:01:26 AM »
Remove anything that is plastic.  Just don't ask me why and I won't tell no lies. H^^
Offline pat king
    • PDK LLC
Re: Enya .29
« Reply #3 on: August 01, 2010, 11:39:45 AM »
If the engine is a Model 5224 the insert is theromoset plastic (Bakelite) and will not be affected by a crock pot. If the engine is a Model 5103 I would take the insert out before you put the engine in the crock pot. I don't know what those inserts are made of.
Pat  H^^
Pat King
Monee, IL
AMA 168941
Re: Enya .29
« Reply #4 on: August 01, 2010, 12:09:54 PM »
Pat  H^^
Many of those have a thin neoprene gasket, it needs to be removed along with the NVA and venturi
Offline bob werle
Re: Enya .29
« Reply #5 on: August 01, 2010, 10:07:44 PM »
It is the 5103 model.  Thanks for youe help.
Bob
ama 5871
