  • July 16, 2025, 06:00:02 PM
Author Topic: Enya 25ss venturi  (Read 2547 times)
Offline scott v.
Enya 25ss venturi
« on: October 03, 2016, 09:03:03 AM »
Hi, does anyone know what the venturi size would be for this motor ? Choices are 6.5, 7 and 7.5mm
Thanks, Scott V.
Online Gerald Arana
Re: Enya 25ss venturi
« Reply #1 on: October 03, 2016, 10:03:51 AM »
I'd go with the 6.5 mm.
Jerry
Offline Brent Williams
« Reply #2 on: October 03, 2016, 02:04:18 PM »
The Enya needle valve assembly has a much bigger cross section than general O.S. FP/LA variety.  The 7.0mm might not be too out of step from a choke area consideration.  Brett Buck has written some good essays on venturi choke area on the LA25 which *should* apply generally to the Enya SS25.   You might like the larger venturi to get appropriate power from the engine.  YMMV.
6.5mm =.255"
7.00mm = .275"
Offline scott v.
« Reply #3 on: October 04, 2016, 06:21:43 AM »
Ok, thanks
Scot V.
Offline Chris Wilson
« Reply #4 on: October 05, 2016, 07:35:04 PM »
The benefit of going with a smaller venturi is that you can always make a small cylinder of sandpaper and abrade it larger and doubly so when the venturi is made of plastic.
MAAA AUS 73427
« Reply #5 on: October 07, 2016, 06:45:59 PM »
Thanks, Scott V.
   What is the diameter of the spraybar?
« Reply #6 on: October 07, 2016, 08:45:14 PM »
Use  the  7 or 7.5 mm  venturie  with the Enya  NVA  , I would use the  7.5  unless it went on a very small light model
Offline scott v.
« Reply #7 on: October 10, 2016, 01:45:24 PM »
I don't have the nv assembly yet but will measure when I get it.
« Reply #8 on: October 10, 2016, 06:04:54 PM »
   What is the diameter of the Enya spraybar?
0.155" for the Enya spraybar.
Offline scott v.
« Reply #9 on: October 13, 2016, 01:08:10 PM »
Thank you everyone
Offline Bill Johnson
« Reply #10 on: October 13, 2016, 09:54:28 PM »
I would think the larger venturi, as Randy suggested, would be the way to go. While you can open up the smaller ones, that's not generally a field adjustment while with the larger one, a layer or 2 of panty hose material will effectively "detune" it and can be adjusted as needed at the field.
Best Regards,
AMA 350715
