  • June 23, 2025, 04:31:21 AM
Author Topic: Enya 19 IV  (Read 4402 times)
Rick_Huff
Enya 19 IV
« on: April 02, 2014, 01:59:44 PM »
I'm having a problem getting an Enya 19 IV to run.  It runs fine with the battery attached to the glow plug, but when the battery is removed, the run gets erratic and it stops.  I've switched out 5 glow plugs (all of different brands) and the same thing happens:  With a brand new plug it runs fine for about 30 sec after removing the battery lead, but then gets erratic and stops.  Re-start the engine with the same plug and remove the battery lead and it goes erratic and stops right away.  I've waited for the engine to completely cool and tried it again and it goes erratic right away after removing the battery lead.  I've taken the plugs that I removed from the Enya and installed them in another engine (a Dooling 29 that is also bench mounted at the moment) and it runs just fine.  Perhaps pertinent is that the compression in the Enya is only so-so.
Anyone have any ideas?
Rick
Re: Enya 19 IV
« Reply #1 on: April 02, 2014, 03:28:27 PM »
The glowplug(s) are too cold for the Enya, but fine for the high compression Dooling .29. Put an idle bar K&B, Thunderbolt, or other good similar glowplug in (i.e., not Fox) into the Enya, and you'll have better results. But don't try that idle bar glowplug in the Dooling!  H^^ Steve
Offline Martin Quartim
    • StuntHobby
Re: Enya 19 IV
« Reply #2 on: April 02, 2014, 03:48:35 PM »
Steve is right, try a hot plug.
If this engine is new and has very tight P/L fit, that could happen even with a hot plug. Just keep on with the break in, it will improve as you run in the engine.
Martin
Rick_Huff
Re: Enya 19 IV
« Reply #3 on: April 02, 2014, 05:50:54 PM »
I have a thunderbolt plug that I'll try tomorrow. I bought the engine new when I was a kid but just don't remember how much I flew it, so it may not be completely broken in.
Rick
Re: Enya 19 IV
« Reply #4 on: April 02, 2014, 06:53:04 PM »
I have one that I broke in in a Flying Fool years ago. I run it with a Fox long idle bar plug and it runs great. I had to fly it in a 4 stroke when I first started flying it as once I leaned it out it would just quit. The shaft bearing took forever to free up. They are a very nice running engine after breakin. I still have mine in the early version of the Tom Tom set up with three lines and a throttle. It has many hours of flying on it and still runs well. It has been in three contol line planes and three R/C planes.
Offline Russell Shaffer
Re: Enya 19 IV
« Reply #5 on: April 02, 2014, 07:58:42 PM »
Too much castor will make an Enya do that.  I had one give me fits, it would run ok with a new plug for a short time and then do exactly what you describe. I was attempting to run it on 29% castor fuel.   It now runs very well on a 50/50 castor synthetic or all synthetic mix.  No, I do not why this occurs but I have some wild guesses.
Russell Shaffer
Klamath Falls, Oregon
    • StuntHobby
Re: Enya 19 IV
« Reply #6 on: April 02, 2014, 09:40:48 PM »
Now and then I see people saying it takes for ever to break in an Enya engine. However, I normally break in my Enya engines with *iron piston* within 1 to 1.5 hours running on the bench and it will be ready for flying.
This is what I have been doing:
Initially I do 10 short runs of 1min with the needle set so the engine is almost trying to break into 2, and letting the engine totally cool between runs.  Then 8 short runs of 2 min and 6 of 3min. Then I do 5 to 8 runs, depending how tight the engine is, of  6 minutes. In this set I pinch the fuel line with care to make the engine run very close to the peak rpm just one hair rich for 8s,  not letting the engine seize or sag, but to hold the maximum rpm it can sustain,  then I release the fuel line, wait about 20 or 30s and repeat the process till the end of 6min. The top rpm improves significantly in this stage. I call the engine ready to fly when I see that there is not more gain in the peak of rpm and as soon as I release the fuel line the rpm returns back immediately to the rpm as  it was before. At this point the engine will be flyable but it will still keep improving flight after flight for the first 20 or 30 flights.
If the break in is done letting the engine run only rich and 4 stroking all the time,  even after several hours on the bench it will probably sag or even seize during the first flights.
Martin
Rick_Huff
Re: Enya 19 IV
« Reply #7 on: April 05, 2014, 10:59:31 AM »
I ran the break-in proceedure that Martin outlined, using a Thunderbolt plug and 50/50 syn/castor fuel.  By the end of the break-in, I was able to remove the battery and have the engine keep running.  However, it would only do this when the head was hot (>150 degrees F).  The engine seemed "stiff" to me, even after the break-in.  I took it apart and found, after some looking, that  the part of the crank where the connecting rod attaches was slightly bent.  Some very careful blows with a brass hammer, some even more careful measurements, and it turns freely.  I ran it today and it ran fine.  It was maxing out at around 12k rpm with a Master Airscrew 9x5.  I don't know if that's good or bad for an Enya 19, but it is running.  Now I just need a plane to mount it on.  In the old days, it was a ringmaster jr.  Any suggestions for a (better) plane?
Thanks for all of your help,
Rick
Offline Balsa Butcher
  • High Desert Flier
Re: Enya 19 IV
« Reply #8 on: April 05, 2014, 12:08:48 PM »
One of the nicest running Enya 35 5224 engines I have was one that went straight into an asphalt circle fro directly overhead. Bent the crank. Straightened it the same way you did and it is still running strong and smooth. Martin's break in procedures have worked well for me too. Good info.  8)
Pete Cunha
Sacramento CA.
AMA 57499
Offline Andrew Tinsley
Re: Enya 19 IV
« Reply #9 on: April 05, 2014, 12:36:28 PM »
Hi Martin,
I have a brand new Enya 5224 that must be 40 years old, I tried your break in method and I am afraid it didn't work on this engine, which is odd because the shaft / bearing clearance is fine ( I dismantled the engine before running (Just to clean out the old stiff oil. Once cleaned up, I could spin the shaft by hand and it took a couple of seconds to stop, Piston Cylinder was a little tight but nothing excessive. After running it in as you suggest, it still will not lean out without sagging. Very odd as everything appears to be OK and I would have said the engine was just about run in from the fits and feel. I am running an Enya No 3 plug and have swopped it for another  new Enya No 3 plug. I am running 25 % oil (50/50 % castor and synthetic the rest is methanol, no nitro.
I am sure your break in procedure works and this engine feels good to go, so is there anything else that could cause the problem described?
Andrew.
BMFA Number 64862
Offline Akihiro Danjo
Re: Enya 19 IV
« Reply #10 on: April 05, 2014, 12:47:41 PM »
Rick
How about an OldTime, 64 years old model for the 50 years old engine? Ringmaster S-1.
I do know that 19-IV has less power than 19-V, but I think it will be able to pull S-1 with a little short lines, 52ft or so. If the model is light, it will be able to do full pattern.
Aki
  • High Desert Flier
Re: Enya 19 IV
« Reply #11 on: April 05, 2014, 01:11:14 PM »
I'd suggest a higher castor content in the fuel. I still run my 5224's on mostly all castor fuel.  Might want to try a different brand of plug also. 8)
« Last Edit: April 05, 2014, 01:39:45 PM by Balsa Butcher »
Pete Cunha
Sacramento CA.
AMA 57499
Offline dennis lipsett
Re: Enya 19 IV
« Reply #12 on: April 05, 2014, 01:23:47 PM »
I don't have time to spend forever running in an engine. What has worked for me is to take an 10/ 4 prop cut it down to an 8 in prop and then start it up in a fast 4 cycle just under breaking into a 2 cycle let run for about 2 min and shut down and cool repeat about 2 more times. Then start it and start pinching the lines when running to force it into 2 cycle and then let it go back to 4. as soon as it will respond to pinching instantly put a standard 8/5 on it and run it in a wet 2. Pinch the line periodically to lean it and let it return. keep increasing the length of time on the run. You will find that as soon as it will hold a setting in a wet breaking 2 it is time to put it on a plane and fly it in the rest of the way.
Make sure that the crank is free in the case as that was more of a problem then the P/L fit. synthetic/castor is the preferred fuel and I use 5/22 as higher nitro is really not needed.
The smaller prop lets the engine rev without load and overheating and you should get good results in a very short time. I fly a Flite streak occasionally with an Enya 19/4 on 57.5 X 015 lines with no complaints to it's flying ability. I broke the engine in probably 30 years ago using that method. It still has great compression and starts in 2/3 flips.
Rick_Huff
Re: Enya 19 IV
« Reply #13 on: April 05, 2014, 02:45:42 PM »
Right now I'm thinking about RSM's P51-15.  I like the idea of having flaps, though they may not be necessary if the plane is light enough.
Rick
Offline Steve Thomas
Re: Enya 19 IV
« Reply #14 on: April 05, 2014, 03:34:16 PM »
The 19-IV is a bit of an unusual one, and quite different to the -V and -VI. A friend has one, and found it underwhelming with the sort of props you'd use on the later 19s. After a bit of messing round, though, he discovered that it really came to life on a Bolly 9.5x6, which is what we often use on PAW 19 diesels, and which would be way too much for a 19-V or -VI. The 19-IV has obviously got a very different torque curve, so don't be afraid to load it up a bit. I've got an unrun one, which I really must put to use some time.
Offline Gerald Arana
Re: Enya 19 IV
« Reply #15 on: April 05, 2014, 06:19:53 PM »
Andrew,
I had/have a Veco 29 like that; wouldn't lean out, just slowed down and quit. It would run fine in a 4 stroke, but...
Turns out that the piston liner was in backwards. I turned it around 180 degrees and VIOLA, screamed like a scalded cat! The person I got it from  had put it together backwards.
Unless that is a pinned sleeve I'd check that out first. Exhaust is HIGHER than the intake and that goes for all two stroke IC engines. (Feel free to correct me if I'm wrong)
Good luck, Jerry
    • StuntHobby
Re: Enya 19 IV
« Reply #16 on: April 06, 2014, 04:17:01 PM »
Hi Martin,
Andrew.
Hi Andrew,
If it is still sagging then your engine is not broken in yet. You need to keep doing the 6min run pinching the fuel line to keep at peak rpm. Eventhough it feels nice and smooth when it is cold. Some engines comes with a tigher p/l fit and will take a few more runs.
What prop are you using?  25% total oil is also what use.
Martin
Offline DanielGelinas
Re: Enya 19 IV
« Reply #17 on: April 06, 2014, 07:29:58 PM »
Ringmaster 307 would be a great plane for the enya 19. The RSM's P51 is also a great choice. Maybe the Brodak tomahawk if light...
Dan
Re: Enya 19 IV
« Reply #18 on: April 07, 2014, 01:58:26 PM »
Hi Martin,
Will do as you suggest, I am using an 8x6 for running in, as I don't like loading the engine too much at this stage! No the liner isn't the wrong way around, I got caught with that one 40 years ago and I always take a "new to me" engine apart. Amazing what you find in some engines! No this engine is sagging because of overheating. The P/L clearance was a little tight as received, but nothing like most new Enyas (of the older sort)! It has a great bouncy feel at the moment, but I will try your extra six minute runs with pinching.
Thanks both,
Andrew.
BMFA Number 64862
    • StuntHobby
Re: Enya 19 IV
« Reply #19 on: April 07, 2014, 05:10:25 PM »
Hi Martin,
Thanks both,
Andrew.
Hi Andrew,
Keep in mind that the engine needs to get at the top *working* temperature, and stay there  for a few seconds, for the break in to happen.
8X6 prop seems to lite for a .35 to break in. I suggest you try a nylon 9x4 and 10x4 to complete the break in.
Martin
