If you have any old OS carburetors laying around, you can unscrew the needle valve assembly from the carb and use it as a remote needle. I have done this many times when my son was young and learning to start his own engines and set his own needles. It's pretty small and light, has 4mm threads if you need to drill and tap anything to mount it on, and the needle seal a LOT better than any of the O-ring type needles out there. When I go to swap meets and look for old R/C engines to convert for stunt, I look for the older OS engines and/or loose carbs that might be broken but have good needles on them. Tower used to still have the needle assemblies in stock but I haven't looked in a while.
