INDEED .
If its a ab initio type device , you WANT it Nose Heavy .
tho maybe , if youre a quick learner , put a second set of holes ( or two ) BEHIND the std engine posn ,
as in use the std back holes for the new front holes , so six holes give two engine positions
C G right aft , itll go all over the sky.
C G right Fwd , it wont - turn or move away from impact , when required .
Muffler Weight'd be a big bit . The little Tongue / chip mufflers weigh diddly squat .
To Clarify , a inch or more nose heavy , or 1/2 inch aft , are about whatd get it NOT companiable
